Miks15
posted on 1/6/09 at 08:39 AM |
throttle cable help
I bought a universal venhill throttle cable kit and just wondering how it all goes together.
This is similar to mine (its the components in the middle that im not sure about)
So how does it all go together? Do the adjusters just sit at the end of the outer or are they attached in some way?
Also how do i attach the clevises? and what are the 6 bits at the top for?(the 4 stepped bits and the 2 smaller bits)
Mikkel
twybrow
posted on 1/6/09 at 09:01 AM |
There are bits there to make up loads of different end cables. The outer, end pieces and adjusters can all be changed.
I used one of those cables, and I soldered a fitting onto the end, having chosed the right size out cable sleeve etc. Just look at the parts you have,
and what you need make it up! If you can put together a BMW based locost, you can make a cable up with your eyes closed!
Miks15
posted on 1/6/09 at 09:04 AM |
well i think i know what bits i need to go where, my initial thought is that one of the solderless nipple gets put on and this sits in the end of the
clevis and holds it on. Its mainly the 6 bits at the top that i dont have a clue what they are?
Mr Whippy
posted on 1/6/09 at 10:11 AM |
what you have there is a heap of fittings to make the same set up as a push bikes brakes, the 6 parts (actually there's 10) are the different
types of adjuster
twybrow
posted on 1/6/09 at 10:57 AM |
The 6 bits are the caps for the end of the cable outer.
