New Topic New Reply
Author: Subject: weight of locost with zetec in it
madteg
posted on 15/1/07 at 10:10 PM Reply With Quote
DOES ANYBODY KNOW.
zetec7
posted on 15/1/07 at 10:21 PM Reply With Quote
Well, I'm still building, but I can't figure out where mine is going to be more than 1100 lbs. (500 kg.). I've added up the weight of the frame and all the parts, figured in wiring, paint, roll bar, oil, etc., and still not much over 1000 lbs. The Zetec is a REALLY light motor (which is why I chose it), especially when you take off the unneccessary bits (power steering pumps, etc.). I'm using a solid rear axle, by the way.
Does that help?
http://www.freewebs.com/zetec7/
stevec
posted on 15/1/07 at 10:25 PM Reply With Quote
Think of the General Belgrano
Johnmor
posted on 15/1/07 at 10:39 PM Reply With Quote
Weight
My Viento, with a V6 is close to 800kgs, but its got a complete interior and fancy corbeau recliners.
So i would think you may creep below 650kg if your lucky and keep comfort to the minimum.
procomp
posted on 16/1/07 at 09:30 AM Reply With Quote
Hi cars with the zetec in can be as low as 490 kg if built for racing but the average westfield with a zetec is more like 560kg for road use with trim and wind screen. 550kg for road use would be a good target to aim for.
cheers matt
iank
posted on 16/1/07 at 10:00 AM Reply With Quote
Zetec isn't that light as it has an iron block (it's around 115kg) rather lighter than a pinto (around 135kg) but no featherweight.
Zetec SE is really light (for a cec) at 80kg ish
Anonymous
Stu16v
posted on 16/1/07 at 07:38 PM Reply With Quote
Err, unless you are refering to the all alloy SE motor, the Zetec is pretty much the same weight as any iron block/alloy headed 4 pot...
Road legal, between 550 and 600kg. Impossible to be specific though. Fitting some silly 17 wheels could add 30kgs to any estimate for a start
New Topic New Reply
