New Topic New Reply
Author: Subject: tin top electronic-type speedo face diameter?
posted on 25/9/07 at 09:11 AM Reply With Quote
if you have a newish tin top (newish = something that would be found in my local scrapyard ) and have electronic speedo - I guess the way to tell if the odometer is digital display instead of numbered wheels, could you measure the diameter of the speedo face?
If it measures around 75 mm diameter, could you post model/make of car.
Ideally black dial with white numbers.
Thanks muchly.
[Edited on 27/9/07 by 02GF74]
posted on 25/9/07 at 11:22 AM Reply With Quote
anyone got a peugeot 306?
with these dials?
can you mesure speedo face diameter?
DarrenW
posted on 27/9/07 at 09:24 AM Reply With Quote
I thought when you said digital speedo you meant one that displayed the moph in numbers rather than a needle pointing at them. Is the one in the pic electronic rather than digital? Just asking as im not sure myself.
posted on 27/9/07 at 09:33 AM Reply With Quote
oops - you are correct - should be electronic speedo.
New Topic New Reply
