CraigJ
posted on 14/12/07 at 07:34 PM |
longer wheel bolts needed
where is the best place to get longer wheel bolts? there currently 55mm but i need them about 70mm. there metro hubs but i know ford nuts fit the
thread so hoping maybe ford bolts will also fit in the hub. Tried rally design with no look. any suggestions? i need 8 off them for the rears.
RazMan
posted on 14/12/07 at 07:37 PM |
How about these guys?
Link
[Edited on 14-12-07 by RazMan]
Raz
Paul (Notts)
posted on 14/12/07 at 07:45 PM |
IF you are looking for wheel studs then Burton power or if as it sounds like you are looking for wheel bolts then give these a call
http://rallynuts.com/motorsport/Wheel_Bolts_2225/Wheel_Bolts_Metric_M12_x_1.5mm_BZP_60°_Taper_NEW_3856.asp
not sure if these are the right pitch but they do others..
Paul
[Edited on 14/12/07 by Paul (Notts)]
CraigJ
posted on 14/12/07 at 07:52 PM |
Link
This site looks like it will help, just need to check the spline size.
Cheers guys.
posted on 14/12/07 at 08:36 PM |
Metro/Rover 100 used 2 different pcds and stud sizes change over was roughly when the K series engine was fitted to the Metro.
[Edited on 14/12/07 by britishtrident]
Avoneer
posted on 14/12/07 at 09:04 PM |
Raldes?????
Pat...
