Ninehigh
| posted on 4/5/09 at 01:45 AM |
Looks like unless you can find a short engine it's going in the back.
iank
| posted on 4/5/09 at 09:48 AM |
Alfa boxer, Renault 5, BMW BEC are all very low engines.
Even the R1 is pretty low mounted for FWD with some thought about replacing the airbox (and packaging some kind of reverse for IVA).
Anonymous
Ninehigh
| posted on 4/5/09 at 06:32 PM |
Would it not be possible to lean the engine back so the pistons are facing more toward you and therefore it would be lower?
mr henderson
| posted on 4/5/09 at 06:54 PM |
Wouldn't really help because the centre of rotation you are suggesting would need to be where the driveshafts exit the diff, some distance back
from the engine.
John
Ninehigh
| posted on 4/5/09 at 07:10 PM |
Ah so doing that would effectively mean that the engine's dragging on the floor? Looking out the window at mine now and from what I can picture
yeah it'd just mean the engine's at a funny angle and when the piston goes it'll hit you in the face...
As another thought why do you not want to go with the mid setup?
mr henderson
| posted on 4/5/09 at 07:18 PM |
I think the OP's idea was that if a FWD set up was used then ALL the mechanical parts from a FWD car could be used, so basically a straight
parts swap.
With a mid engined set up there are quite a number of technical difficulties to be overcome. For instance, the gearchange, and as another for instance
the need to either fit a handbrake system to what was the front wheels (now at the back) or find a way of allowing what was the rear wheels (complete
with handbrake system) to accept drive shafts.
All doable, of course, but not really in line with what the OP was asking
John
[Edited on 4/5/09 by mr henderson]
seansverige
| posted on 5/5/09 at 11:54 AM |
Seconded - stick to the brief: making it mid-engined or a having a Seven's bonnet line misses the point.
(GRRR, please correct as needed) To me, 2+2 - both the Quantum specifically and the term generally - suggests something that's good looking,
good fun but with a modicum of practicality: something you could contemplate taking on a week's driving holiday with more than a single change
of clothes. As I see it, whether the car is front or rear drive is almost secondary to the fact it's front engined, which it is for packaging
reasons as a 2+2 (unless you want to re-invent the Porsche.) RWD would be nice but as the 1-series isn't near cheap enough yet as a donor, so
this basically means a 3, which means keeping the wheelbase unless we want to hack the drivetrain up - which negates the parts swap element. The FWD
option is simpler, cheaper and there are a plethora of candidates.
GRRR: how important is it that this is a spaceframe? I guess if you're seriously considering building something this is the most most practical
type of structure though it has been pointed out this is difficult with struts I have been reading about the current TT's spaceframe - but I can
only find images of the R8's chassis, and I suspect it's a hybrid structure anyway.
The Audi TT, VW BlueSport Roadster, and Seat Tango all demonstrate that good looking front engined, strut-suspended cars are possible. Comparisons to
the Jester and Firecat are inherently false - these are b*stard children of a Seven and a buggy - not 2+2's. I can't find data for their
length / wheelbases, but they're both short which makes them look dumpy and a 2+2 will by definition need to be bigger.
So the question is even if it's not your cup of tea, do you think there IS a market for such a vehicle? If not, why not - and if you are
interested, what would be your selection criteria?
Still wouldn't go for a Quantum, but my interest has been piqued - couldn't make Stoneleigh, but if at Newark or Donny will definitely
take a closer look and have a chat with some Quantum owners
