RK
| posted on 26/10/09 at 01:05 PM |
What sort of front mod do you mean? I thought of closing off all the openings around the engine, then I thought of how much heat a turbo car can
generate, and left it alone!
All I know is that there is no lift without drag, and downforce is just lift upside down.
Mr G
| posted on 26/10/09 at 03:53 PM |
quote: Originally posted by thunderace
hes bolted on a dutton back end to make it look cool
How vary dare you!
Rob Palin
| posted on 27/10/09 at 02:05 PM |
You can gain something from ensuring fitting ducting so that all the air that enters your nosecone can only go through the radiator. Then make sure
it can get out of the engine bay, through vents / louvers etc on the top and / or sides.
The biggest benefits though come from reducing the lift on the front wheel arches. They're not pretty, but getting longer ones that wrap around
more of the circumference of the tyre is very beneficial. The further around the front face of the tyre they cover, the better. Louvers on the top
of the wheel arch are also great, though their dirt & water shielding properties will suffer.
