beaver34
| posted on 4/12/09 at 07:39 PM |
new arms,
beaver34
| posted on 6/12/09 at 06:18 PM |
update,
time for the start of the winter resto, didnt really mean to get this far but it sort of happened, only wanted to take the dash off, but i didnt even
do that, i am getting better though, just under 3 hours from driving in to the garage and 1 cup of coffee
beaver34
| posted on 13/1/10 at 09:22 PM |
havent updated it in a while been xmas and all that, ill just upload the pics you can prob work it out from there,
beaver34
| posted on 13/1/10 at 09:28 PM |
took a trip to shawspeed just bvefore xmas to pick my present to myself up, (sad i know)
near enough got snowed in while i was there! got stuck trying to get out of the services! lonely beetle
anyway went to pick this up, wanted one for ages and ages, its great runs straight into the omex ecu and picks all the sensor up from there, just had
oil temp and pressure to add,
no time messing about, got it powered up
beaver34
| posted on 13/1/10 at 09:34 PM |
parts piling up in the garage,
getting near finishing removing parts
thats where im at at the moment, going to autosport on friday for some motivation to do something with it
RK
| posted on 14/1/10 at 02:16 AM |
Did you decide on a colour? I think white looks good. Just MHO.
beaver34
| posted on 14/1/10 at 08:07 AM |
yeah, it will be white and black, but which parts white and which black is still undecided,
thanks
Yellowperilous
| posted on 25/1/10 at 05:32 PM |
Shawspeed
I have the Shawspeed in the picture at Brands Hatch. It's been on the road and going really well since first reg in September 04. It is my son
driving at Brands and I drove your car for many laps on the same day. My engine is same state of tune as yours giving 175bhp. This winter's
upgrade is a shortened sump having smashed mine last year. We must make contact and meet up one day this summer as there arn't many Shawspeeds
about.
Regards
Mike
beaver34
| posted on 26/1/10 at 07:22 PM |
about.
Regards
Mike
very good mike, hope my car was ok for you!
johnH20
| posted on 11/3/10 at 08:02 PM |
Hi, very impressive all round. What exactly is your engine spec for 175 bhp?
Funnily enough I am thinking of doing the reverse to you - a racing Puma engined Ka!
beaver34
| posted on 11/3/10 at 10:45 PM |
Thanks,
your inlet on a frp is an issue will not clear the bonnet,
My spec was Shawspeed ss4 cams
Shawspeed uprated rod bolts
Shawspeed big valve worked head
hayabusa throttle bodies
Omex managment
rev limit at 8k did 10k like this, i've pulled it apart now for rebuild should see 200bhp when i've done
beaver34
| posted on 20/4/10 at 09:53 PM |
long time no update so ill add some more pics, i forgot about the thread to be honest
beaver34
| posted on 20/4/10 at 09:54 PM |
beaver34
| posted on 20/4/10 at 09:57 PM |
old and new cams, abit bigger
beaver34
| posted on 20/4/10 at 10:01 PM |
chassis finished!
back at home
beaver34
| posted on 20/4/10 at 10:06 PM |
beaver34
| posted on 20/4/10 at 10:07 PM |
there we are all up to date for now, will be cracking on in the next few weeks to get it back on the road asap
Madinventions
| posted on 22/4/10 at 10:39 AM |
Just a quick question - looking at your engine shots from the first page, your tensioner pulley is considerably smaller than standard.
I've got a Puma engine fitted in my Mojo and space is so tight that this pulley rubs against the chassis durinng hard cornering...
I'm using the tensioner assembly from a 1.25 Fiesta which is similar to yours, but I was wondering about your setup. Is your tensioner pulley
smooth faced? If so, then I think that it was originally the other idler pulley that has been moved onto to tensioner. Do you know what mods were
done to the tensioner to make it fit? The pulley on my tensioner is about 100mm diameter. This is a pic of my old 1.25 engine, but the belt routing
and pulley sizes are the same on my Puma engine:
I've emailled Shawspeed with a similar enquiry but I thought I'd ask you directly as well..
Any thoughts gratefully received.
Ed.
View my band website:
http://www.shadowlight.org.uk
beaver34
| posted on 22/4/10 at 09:31 PM |
mine is a standard ford item,
more than likley just a later super session of your part, i also work for ford so if you get the the engineering part number from your, is a
combination of letters and numbers like 98a-1437-aa i will check it agaisnt mine and the lastest number from ford
Madinventions
| posted on 22/4/10 at 10:25 PM |
The one I've got fitted is from a 1996 1.25 Fiesta, no A/C, no PAS and is part number 96MF-6A228-80.
Ed.
beaver34
| posted on 19/2/11 at 04:28 PM |
fogot about this thread, ill update but not as in depth as there would be alot of images
beaver34
| posted on 19/2/11 at 04:31 PM |
MakeEverything
| posted on 19/2/11 at 04:42 PM |
Quality mate. Looks really good.
Kindest Regards,
Richard.
beaver34
| posted on 19/2/11 at 04:44 PM |
now the engine at the beginning of the year was supposed to be taken to the next level before it was n/a standard rods and pistons shaspeed big end
bolts, ss4 shawspeed cams busa bodies and a trick head and it made 175bhp at 8000rpm, i had purchased some steel rods accralite pistons and ss6 cams
and a set of jenvey dth bodies and was looking for around or over 200bhp n/a, the engine got built but wouldnt turn over by hand, it turns out the
rods where mixed up anyway i lost the love for it at that point and left it in the garage over summer as i also have a old vw camper that i use to do
the show round with the local club and we enjoyed using that,
anyway, i decided i want to build a turbo engine one day and called jon at shawspeed and he said yes he would like to do it, so we are doing it!
so 1600 zetec se,
lightened balanced knife edged crank
steel rods
custom accralite pistons
shawspeed turbo spec 2 cams making there debut
customer shawspeed inlet and tubular exhaust manifolds
garrett gt2871rs turbo
turbosmart external wastegate
omex 600 ecu
some up to date pics
thats about it for now,
piper have made the cams to spec and they should be here next week, then we can build the engine up!
beaver34
| posted on 22/2/11 at 09:41 PM |
arrived today
its mad how slim it is,
