<<  1    2  >>
New Topic New Reply
Author: Subject: 1:8 scale balsacost!
steve m
posted on 10/10/05 at 06:42 PM Reply With Quote
Thanks Marcus,
we have all had a good laugh over the years ??? and yes still running a xflow, (no 4)
Yes, i did make the cycle wings and bonnet bulge, the nose cone and rear arches were off a "lotus 7" not caterham, and all have been re built to the spec i wanted,
"Steve (M)
Did you make all your bodywork (nosecone/bonnet/sides/scuttle/arches and rear panel)?"
why would i do that ???
it would just end up looking like every other fiberglass "7 " clone on the market,
i had in my head right from the start the exact look that i wanted, and it had to look like a "7"
as said on here before, we are all different, and have different idea's
its just that mine reflects the original "lotus 7" concept
kevano
posted on 10/10/05 at 08:43 PM Reply With Quote
miserable old git(about as old as his crossflow!!) springs to mind!!!
it's really imformative and helpful and a good laugh too!!!:
G.Man
posted on 10/10/05 at 09:31 PM Reply With Quote
I am starting my build on the 17th "kit "delivery" day...
Wanna start a sweepstake on how long before its ready for SVA
Opinions are like backsides..
millenniumtree
posted on 11/10/05 at 03:49 PM Reply With Quote
I put the tranny tunnel in and most of the rear end. For the rear, I used some thick aluminum wire (actually made for wiring bonsai trees). It's got this nice brown coating on it, which should make it easy to paint. And, in 1:8 scale, it's about 3/4 inch thick.
Totals so far:
Time: 5 hours
Money: ~6 dollars
Balsa Frame 4
Balsa Frame 4
posted on 11/10/05 at 06:05 PM Reply With Quote
how did you get it looking so accurate and square? did you jig it or just hold it over drawn triangles etc? Is the glue flexible or solid?
when i did one, ((not locost)1/4 scale, but still only 18" long!), i drew it onto a piece of wood and then used a hot glue gun and just held the bits in place til it cooled.
[Edited on 11/10/05 by JoelP]
Rorty
posted on 11/10/05 at 09:38 PM Reply With Quote
Totals so far:
Time: 5 hours
Money: ~6 dollars
Balsa Frame 4
Balsa Frame 4
Are you going to publish a book "Build your own balsa car - for less than $10"?
It does look particularly square and to scale. Well done.
Cheers, Rorty.
millenniumtree
posted on 12/10/05 at 06:27 PM Reply With Quote
It's not particularly square, and several of the measurements are off.
The tranny tunnel is too high, and the back is twisted slightly.
The glue I'm using is a superglue that quickly goes tacky, but takes a long time to harden up. Once it's hard, it's like regular superglue... Won't budge. It's a nice gap filler too, so if my measurements are a bit off, I just squirt some extra glue in there and it fills the gap real nice.
I plan on covering it with sheet aluminum that I bought for another project, and maybe carving the nosecone out of a block of wood. If that works well, I'll make a mold of the cone in something, and try heat-gunning some thin plastic into the mold for a future balsacost. We'll see.
I know some of you may think this is silly, but I'm viewing it as a testbed for future projects, and eventually, building the real car. I can already tell I'll need to be more thorough in my measurements.
I might make 10 $20 balsacosts before I ever start on the real thing. I might even work my way up in size from 1:8 scale to 1:6th, 1:4, 1:2 (single-seater) and then build the full-size, roadworthy, expensive car.
Rorty
posted on 12/10/05 at 09:41 PM Reply With Quote
It's far from silly. Most car manufacturers begin with scale models to assess everything from asthetics to functionality. Plus it gives you a better understanding of the individual elements and the order of assembly.
You wouldn't catch me building a girlie thing like that though.
Cheers, Rorty.
millenniumtree
posted on 18/10/05 at 06:27 PM Reply With Quote
New bits:
Floorpan
Nose Bottom plate
Seatback metal
Seatbelt mount points (all of above from aluminum roof flashing)
Rear wheel arch curved support (out of aluminum wire)
I've been having a hell of a time locating ANY model cars in 1:8 scale!! I found a few bikes, but they're all "choppers" with harley motors. And all the 1:8 scale model cars are either R/C (with no nice motor look-alikes) or so bloody expensive I could buy 2 donors instead of the model. (like, 2 grand, literally!)
I might be able to get a die-cast 1:10 scale supra or skyline and just PRETEND it's a smaller motor from another car.
Another option is just to fit a cheapo electric motor under the bonnet and call it "rotary"!
Balsa Frame 5
Balsa Frame 5
[Edited on 19/10/05 by millenniumtree]
Simon
posted on 18/10/05 at 08:04 PM Reply With Quote
Joel,
If you want to get a scale model square, draw up plans like you did on the 8' x 4' board, but cover the paper in candle wax (just rub candle hard on the paper). Lay wood over plans and pin in place, then stick with an alaphatic (sp?) glue, or a thin cyano.
Simon
[Edited on 18/10/05 by Simon]
millenniumtree
posted on 19/10/05 at 02:35 PM Reply With Quote
I guess it's pretty square, except for a couple of mis-measurements (which didn't really throw off squareness as much as height in certain areas.)
NOTE: All following measurements are in scale, so when I say 1 inch, I mean 1/8 inch.
Today, I had to correct a major flaw in the rear. The seat backing plate was too wide by 2 inches. I put the pipes running up the sides of the seat back panel too far out, and this would have not allowed me to put the rear trailing arms in. I did a couple of precision cuts of the superglue and removed these pipes, scribed the aluminum and bent it off 1 inch on either side, then relocated the pipes 1 inch farther in, to where they should have been in the first place.
Considering the ease with which this was accomplished, I may take an inch off the height of the propshaft tunnel too. I'm glad I'm messing things up now. Cutting superglue is sure easier than de-welding.
Simon
posted on 19/10/05 at 06:57 PM Reply With Quote
milleniumtree,
It's a bit late, but I reckon if you'd built in 1/12 scale, you could have used a bike engine from a Tamiya kit!
Simon
caber
posted on 19/10/05 at 08:02 PM Reply With Quote
When you do the real thing I am sure you will learn to handle an angle grinder in the same deft way as you are using a scalpel to cut the superglue, the grinder will do just the same for your dodgy welds:-)
Caber
<<  1    2  >>
New Topic New Reply
