New Topic New Reply
Author: Subject: Cam Oil Seal
bbwales
posted on 24/11/08 at 09:28 AM Reply With Quote
Cam Oil Seal
Hi All,
I have an oil leak from where the Distributor goes to the Cam, I have tried Ford but they will only sell me 5 seals at £45, any ideas where I could get a single seal?
The engine is a 2.0 ltr DOHC circa 1992 out of a Sierra.
Thanks for your help.
Bob
posted on 24/11/08 at 09:34 AM Reply With Quote
A local motor factor will probably sell you a top end gasket set for less then £20 with all the seals and gaskets you need for the engine.
Alternatively try Burton Power who should be able to supply the kit or individual seals you need.
posted on 24/11/08 at 07:44 PM Reply With Quote
Have you tried to buy a top end gasket kit for that engine ? last one I got was well over £100 . Burtons may be your best bet
flak monkey
posted on 24/11/08 at 07:49 PM Reply With Quote
http://cgi.ebay.co.uk/FORD-2-0L-DOHC-8V-HEAD-GASKET-SET-VDT-481-2_W0QQitemZ200226303005QQihZ010QQcategoryZ21654QQcmdZViewItemQQ_trksidZp1742.m153 .l1262
Gaskets for Classics on ebay is always a good bet
Sera
http://www.motosera.com
posted on 24/11/08 at 08:00 PM Reply With Quote
IIRC the timing chain tensioner is a use once item that needs replacing when the head is removed , in fact the chain itself may have to be replaced as well . Doesn't appear to be tensioner or chain in that set. It has been a while since I last worked on one so I could well be wrong?
New Topic New Reply
