dubstar_04
posted on 2/12/08 at 07:43 PM |
Nuts and Bolts
I want to order a load of nuts and bolts for my build.
I was wondering what the most common bolts setscrews, nuts etc are?
I am probably going to order them in bags of 100 from screwfix so I need to get the most common ones really.
Another option would be to buy smaller quantities from the local engineering suppliers but I figured it would be handy to have a good collection of
fasteners for any future projects!
Many thanks,
Dan
posted on 2/12/08 at 07:45 PM |
M8s. Can't get enough of them. Always using M8 bolts and nuts. And washers. Lots of washers.....
And nylocks. You can re-use bolts and washers but re-using nylocks ain't good....
Screwfix are good in bulk....
RichardK
posted on 2/12/08 at 08:07 PM |
Buy normal nuts and replace them with nylocs at the end of your build.
Rich
Gallery updated 11/01/2011
pewe
posted on 2/12/08 at 08:10 PM |
Besides ordering M8s I tried to use bolts which are graded for strength 8.8 or more.
It strikes me that for the extra cost involved I'd rather have peace of mind than the off-chance a lower grade bolt failing, especially since
our applications are probably more vibration prone than most others.
For that same reason I've tried to avoid stainless as they tend to be more brittle.
HTH.
Cheers, Pewe ![](/images//smilies/cool.gif)
designer
posted on 2/12/08 at 08:16 PM |
ALWAYS use top grade bolts; for everything!!
Theshed
posted on 2/12/08 at 08:40 PM |
The best rant on bolts is to be found in "Engineer to win" series of books. I agree with Designer above - I would never use a bolt from
screwfix in a car that I wanted to drive fast. You can safely use capscrews of industrial quality or aircraft bolts are just fine.....but not locost!
iank
posted on 2/12/08 at 09:04 PM |
Screwfix bolts are grade 8.8, except the cap screws at 12.9, or do you have a reason to believe they are lying?
Now B&Q bolts are another matter
[Edited on 2/12/08 by iank]
Anonymous
blakep82
posted on 3/12/08 at 12:08 AM |
i've actually started using cap head bolts for everything. i think they look better, plus grade 12.9, you can't go wrong.
but thats not the question. M8, M10 and a few M12 probably. but whatever number you get, you'll probably need at least twice as many washers as
bolts, and nuts too. as said, build using normal nuts, and only use nylocs for the final tightening up
________________________
posted on 3/12/08 at 10:01 AM |
^^^ as above .... but no matter what diameter/lenth you buy, the one you need in a hurry will be the one size you don't have.
thunderace
posted on 3/12/08 at 12:35 PM |
b&q bolts are made of zink ![](/images//smilies/bigsmile.gif)
iank
posted on 3/12/08 at 01:20 PM |
I thought it was silver painted cheese.
Anonymous
