New Topic New Reply
Author: Subject: What I have ordered this for?
dubstar_04
posted on 5/12/08 at 12:43 PM Reply With Quote
I have ordered a load of fasteners from the local engineering suppliers and I also ordered a 13mm and an 18mm drill bit.
What have I ordered the 18mm for I can't remember now!!
I knew why when I asked for it!!
The 13mm is for 1/2" suspension bolts, i can remember that!!
[Edited on 5/12/08 by dubstar_04]
Mr Whippy
posted on 5/12/08 at 12:48 PM Reply With Quote
headlamp mounting bolts tend to be around 18mm
dubstar_04
posted on 5/12/08 at 12:51 PM Reply With Quote
Its not that...
I can't believe this. I am only 25 and I am going completely...
Hang on what was I saying?
omega0684
posted on 5/12/08 at 12:52 PM Reply With Quote
what about harness mount bolt holes?
dubstar_04
posted on 5/12/08 at 12:55 PM Reply With Quote
No not them...
I like this game!!
I am going to take it back and get something more useful unless I can remember why I ordered it!!
I am making up my wishbones and finishing off my axle if that helps...
... I'm going bonkers!!
posted on 5/12/08 at 12:56 PM Reply With Quote
Trepanation?
I believe it was once used for madness!
dubstar_04
posted on 5/12/08 at 01:00 PM Reply With Quote
what I bought an 18mm drill bit to drill a hole in my head to stop me being forgetful but I forgot what I needed it for?
That might be it but I have completely forgotten!!
Benzine
posted on 5/12/08 at 01:03 PM Reply With Quote
for drilling 18mm holes?
iank
posted on 5/12/08 at 01:07 PM Reply With Quote
Call me old fashioned, but I bought a 1/2" drill for that size.
Anonymous
dubstar_04
posted on 5/12/08 at 01:10 PM Reply With Quote
I assumed by the time the holes were painted they would be too small if I used a 1/2" or shall I swap my 18mm for a 1/2" instead?
maartenromijn
posted on 5/12/08 at 01:17 PM Reply With Quote
Drill 18mm holes in order to cut m20x1.5 thread for the top BJ!
That must be it!
BLOG: http://thunderroad-super7.blogspot.com/
Mr Whippy
posted on 5/12/08 at 01:18 PM Reply With Quote
I'd not take a coat of paint into consideration, use a 1/2 drill
dubstar_04
posted on 5/12/08 at 01:20 PM Reply With Quote
I think that might be it!! I have bought the sleeved inserts now and I am going to turn the piece of steel so I won't need an 18mm drill bit...
.. well not until after I have taken it back anyway!!
has anyone seen my marbles?
maartenromijn
You need a 18,5mm drill for M20x1,5 btw.
redscamp
posted on 5/12/08 at 01:39 PM Reply With Quote
surely you bought the 18mm to debur
the 13mm hole?
posted on 5/12/08 at 01:41 PM Reply With Quote
Holes for rivnuts?
DarrenW
posted on 5/12/08 at 01:48 PM Reply With Quote
Brilliant That made me chuckle today.
DarrenW
posted on 5/12/08 at 01:49 PM Reply With Quote
You can use it to drill holes in the floor to let the water out. Oh the joys of se7en motoring - youve got that to look forward to.........
posted on 5/12/08 at 03:18 PM Reply With Quote
you probably wanted 1.8 mm to drill carb jets but the postman stole the dot.
omega 24 v6
posted on 5/12/08 at 03:57 PM Reply With Quote
Are you using 20mm thread top ball joints?? If so drilling 18mm and tapping the same.
jacko
posted on 5/12/08 at 04:29 PM Reply With Quote
That's very worrying your building a car and can't remember things
I hope you remember to nip nuts and bolts tight
Vindi_andy
posted on 10/12/08 at 10:17 AM Reply With Quote
That sounds painful to me. is that so he remembers what he is supposed to remember i.e. if you can't remember then its time to nip nuts OUCH
New Topic New Reply
