rayward
posted on 19/12/08 at 08:19 PM |
Project mini: your opinions???
my mini project is about to begin, either bike engined or honda type r, what are the masses views on drive/engine position?
big_wasa
posted on 19/12/08 at 08:24 PM |
I like the front engined, front wheel drive bec in the ppc a few months back
very trick
speedyxjs
posted on 19/12/08 at 08:28 PM |
Iv always wanted to try a mid engine, front drive set up in a mini.
Basically you have a big lump in the rear, mounted backwards. Gearbox coming through to the front mounted diff (this could be a ferwd car diff mounted
upside down with breather and drain plug reversed). Drive shafts to modified front hubs
[Edited on 19-12-08 by speedyxjs]
Danozeman
posted on 19/12/08 at 08:41 PM |
Id put a type r in the back with rwd. But a 2.2 from an accord rather than 2 litre from a civic.
Dan
speedyxjs
posted on 19/12/08 at 08:45 PM |
Problem with that is it may be tricky when it comes to going round corners
posted on 19/12/08 at 08:54 PM |
Front/Front BEC I reckon.
You might want to drop a U2U to "minicooper" on here. He's built/building a Front/Front BEC AND a Mid/Rear BEC so might be able to
offer some practical build and driving opinions.
woodster
posted on 19/12/08 at 09:01 PM |
This site may help ... a bit pricey .. some good vidsto help get you thinking
http://www.pro-motive.co.uk/R1KitInfo.html
Antnicuk
posted on 19/12/08 at 09:17 PM |
it has to be RWD, i like the rotary engined mini that was in a car mag about a year ago. (but then i'm biased) Front engine rwd, but i like
the Honda engine.
Isnt a mini van with a vtec engine one of the fastest things around the ring at one point? Not sure if its FWD or RWD.
Bolting the whole honda subframe in the back has to be easiest option though. Seen it done with an MR2 turbo set up!
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
stevec
posted on 19/12/08 at 09:47 PM |
Front engine front drive or front engine rear drive, you will probably live slightly longer that way
carpmart
posted on 19/12/08 at 10:11 PM |
Voted rear/rear - Z cars style!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
TGR-ECOSSE
posted on 19/12/08 at 11:06 PM |
My personal opinion would be to maybe possibly put an A series engine in the front
twybrow
posted on 20/12/08 at 12:53 AM |
Twin bike engine!! One driving front and one the rear (R1 probably). There are kits available for both, so just combine 'em both with some
Locost thinking!
Davey D
posted on 20/12/08 at 08:29 AM |
Its got to be an FF setup with a light bike engine!
id have thought an FR setup would be a bit hairy on the limits with such a short wheelbase?
ReMan
posted on 20/12/08 at 08:37 AM |
FF
Sorely tempted towards one for my next project.
BEC with a roof
imp paul
posted on 20/12/08 at 09:31 AM |
hmmm zx14r rear wheel drive would be the muzzy nuts come to the dark side you know it makes sense
Mark G
posted on 20/12/08 at 09:54 AM |
I'd say it depends on the engine. If you go for VTEC I'd stick to FF but if you decide on BEC then I'd say RR
GBaggott
posted on 20/12/08 at 10:55 AM |
I'm just about to start building a rear engine rear wheel drive mini. Ive built a few cars already and all been bike engined (MK,MAC 1, MNR) so
i think bike engine is the best way.
The only question i had in my mind was do i want to use it everyday? if so i could do with a reverse, and in that case a vtec would be better.
You can get the quaiffe ATB reverse diff but its very expensive.
iank
posted on 20/12/08 at 01:12 PM |
Lots of info/ideas here http://www.16vminiclub.com/
Anonymous
rayward
posted on 20/12/08 at 06:04 PM |
cheers fellas,
decide on Rear mounted BIKE engine RWD
Ray
