roadrunner
posted on 21/12/08 at 08:36 PM |
Wet patches in tin top
I have two wet patches in the foot wells of my golf, i do know there are rubber patchy thingys under each foot well, are these supposed to be sealed
over like the rest of the under carriage or left clear.
Thanks Brad.
posted on 21/12/08 at 08:50 PM |
Check the bulkhead drains under the bonnet. The drain holes get bunged up with dead leaves .
roadrunner
posted on 21/12/08 at 09:15 PM |
Its also effecting back seat wells too.
MikeR
posted on 21/12/08 at 09:20 PM |
friends got a seat leon where the door seals have gone. she parks on a hill, depending which way the car faces she gets either 1" water in the
front or rear.
austin man
posted on 21/12/08 at 09:39 PM |
I have a Golf MK4 if parked on the pavement water gets into the car via the door seals too
matt_gsxr
posted on 21/12/08 at 09:47 PM |
drill holes in the floor and remove the carpet.
Locost solution.
Matt
f1ngers
posted on 21/12/08 at 10:22 PM |
Also worth checking the the polythene liner behind each door panel is sealing properly. Water that gets past the window rubber flows into the car
rather than down inside the door and out the bottom.
Also the drain holes in the bottom of the doors can get blocked and in heavy rain the doors start to fill up and overflow through a poorly sealed
polythene lining and into the car.
omega0684
posted on 21/12/08 at 10:31 PM |
not sure about the back seat footwells but i had a similar problem in that i was getting regular puddles of water in both footwells,
turned out the the heater radiator had sprung a leak and as it was mounted behind the dash it was leaking down into the footwells.
as a result the car was over heating a lot and i was regularly topping up with water,
just a thought......
focijohn
posted on 21/12/08 at 11:46 PM |
Hate to second the matrix but that or door seals have cured most the problems at work???
Pressure test the cooling system and x your fingers
HTH
John
[Edited on 21/12/08 by focijohn]
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
AR-CoolC
posted on 22/12/08 at 11:47 AM |
What golf is it? Mk4?
If so there have been quite a few "issues" with water entry.
First off, has if got a sunroof? if it has check the drain tubes are not blocked.
Second, check under the plenum chamber cover, that there are no leaves etc blocking the drains at each outer end. and then that the pollen filter is
correctly fitted and not bunged up with leaves etc.
Third, there is a problem with water coming past the foam seal on the metal inner door cassette, the locost solution to this, is remove the door
panel, and smear the lip around the cassette with silicone sealent. Also check the outer door seals fro signs of damage, or marks where water has been
getting past.
http://uk-mkivs.net/forums/t/237075.aspx?PageIndex=1
http://uk-mkivs.net/forums/t/41893.aspx
Imagine what it would be like if there were no hypothetical situations.
Agriv8
posted on 22/12/08 at 12:13 PM |
Passat suffered with leaves blocking the drain holes on the scuttle just bellow the screen.
when parked with Ns on kirb and os on road used to fill up and track down where the ECU connectes through the bulkhead to the fuse bord realys act.
fixed by taking it apart and sealing with silicone.
still dry 5 years later.
Regards
Agriv8
posted on 22/12/08 at 12:29 PM |
This all reminds me of my dear old MK1 Fiesta - used to leak like a seive. Punched a few holes in the floor (through the rusty patches ) and let
it drain out.
Never had a problem with my old Leon, but you'd think manufacturer's would have this sussed by now really.
posted on 22/12/08 at 01:01 PM |
The same thing happened to my daughter's Mk4 Golf Gti - the carpet used to get sodden when the wind blew the rain in the right direction.
Considering how much it cost when it was new, it was a heap of absolute rubbish - absolutely full of well-documented faults (e.g. front windows that
fall into the door, glove compartment lock failure, leaks and, apparently, a flywheel that falls of the crank! - had all these faults, apart from the
last - thank heavens). Thankfully it's now long gone...
roadrunner
posted on 26/12/08 at 08:44 PM |
Thanks fellas lots of usefull ideas to check out , as for your daughters GTI David, mine has been spot on really, mines the 170 V5 cracking engine
really smooth but crap chassis especially after driving a BEC seven.
