New Topic New Reply
Author: Subject: Hehehehe:D
Simon
posted on 31/1/09 at 07:34 PM Reply With Quote
Hehehehe:D
Good value or what
1. 3.9 engine (83k miles).
(The engine is in perfect running order. The heads have just been skimmed and new composite gaskets used. The exhaust ports have been ground out to match the manifolds to aid gas flow. It comes complete with ECU, alternator, new air flow meter, new belts etc).
2. Four speed ZF auto box.
(works perfectly but whines on load).
3. Transfer box.
(Just been rebuilt using all new bearings. The chain and sprockets are perfect. The diff has been rebuild and the viscous coupling works perfectly).
4. Both prop shafts.
(Both in GWO).
5. Complete rear axle.
(Rebuilt 24 spline Diff and new brake discs and pads but the ABS sensors are not included).
6. Front 24 spline Diff.
(In good working order).
7. Both swivel hubs.
(These have both been rebuilt and come complete and ready to bolt on and include drive shafts and new ventilated brake discs. ABS sensors are not included).
8. Complete wiring loom.
9. Set of 4 Range Rover 3 spoke wheels with 2 x “Wide Conqueror A/T 205/80R16” tyres and 2 x “Westlake 205/80R16” tyres all with at least ¾ of their tread.
10. There is also a box of smaller items such as Front shock absorber turrets, Viscous fan, a pair of new Bump stops, Parts service and trouble shooting manual on CD, New oil filter, Steering tie bar with new ball joints, Drag link, Original air flow meter (Now proved to be in GWO), full set of relays, Fuel pump, Dial gauge pod, Ignition switch and key etc etc.
11. A set of 4 new Britpart heavy duty standard height road springs.
£550
Bargain
All except engine loom ecu etc back on the bay next week
Wehay, working car next weekend hopefully
Simon
[Edited on 31/1/09 by Simon]
NigeEss
posted on 31/1/09 at 11:39 PM Reply With Quote
Nice one.
Mate of mine has a full injection system with ecu sat in his shed from a Rangy. Was on a
running car that ran badly and he thought it was faulty. Swapped to carbs and it was just the
same.Doubt he'd want much for it.
New Topic New Reply
