New Topic New Reply
Author: Subject: Bullet camera's what's it all about !
mark chandler
posted on 8/2/09 at 10:50 PM Reply With Quote
Hello
I have got myself a little DVR recorder so next step is a bullet cam, but what one.
CMOS looks like a load of rubbish so will not bother with one of them, so now a couple of choices.
Sharp seem to make the lower end, 420 lines.
Sony the top end, 420, 480, 520, 580.
Now I have tried to look at previews on sites, 420 looks pretty grainy, but 480/520 is looking pretty good but is it worth the extra for a 520 camera?
Anyone got any vids I can have a looksee using 480/520 sony powered stuff.
NB/ If I record straight from the TV on to my DVR then play back on my laptop its comparable with BBC iplayer quality.
Of course anyone got a camera going cheap let me know
Cheers Mark
austin man
posted on 8/2/09 at 10:56 PM Reply With Quote
You also need to consider the audio quality, I have a bullet cam that came with a dvr the picture is good but the audio is crap when you film in the car all you can hear is a constant noise, it appears that the microphone is way too sensitive. I have seen bullet cams where the mic can be placed away from the cam they appear to have better sound quality.
posted on 9/2/09 at 04:43 AM Reply With Quote
stick the mic in a padded bag, that sorted the noise for me.
oldtimer
posted on 9/2/09 at 07:57 AM Reply With Quote
Microphone in a condom usually kills most buffeting sound, but usually you need a remote mike.
Omni
posted on 9/2/09 at 08:25 AM Reply With Quote
Now that really is practising safe recording
(I'll get my coat........)
[Edited on 9/2/09 by Omni]
bimbleuk
posted on 9/2/09 at 08:42 AM Reply With Quote
Sony 480 is more than adequate if you're using a composite analoge connection ie. the AV in on a DV a camera.
On my Striker I use a remote mic tucked out of the air buffeting. On our Radical Clubsport I used a "Zorst" mic from DogCamSport.co.uk which only records the really loud stuff without destortion.
Example clip from a Radical Clubsport round Combe
[Edited on 9-2-09 by bimbleuk]
v8kid
posted on 9/2/09 at 09:40 AM Reply With Quote
Great fun to watch but the picture quality is wee awfull.
Is it the web hosting site that is rubbish or the camera?
Jubal
posted on 9/2/09 at 09:54 AM Reply With Quote
What compression does the DVR use? I have a 520 lines bullet camera and DV cam but compress down to mpeg2 for storage (720x576, 25fps). The quality is excellent but it's a right pain having to process/compress everything. I'm therefore thinking about a DVR.
This results in a 300Mb file for about 10 mins of footage so anything you see on the net is compressed much further. I'll do a short clip at full resolution tonight. Be interested to see if anyone's DVR experience compares. TVM.
posted on 9/2/09 at 10:34 AM Reply With Quote
trawl round some of the cycling sites - quite a few peeps have these as helmet cams to record bad motorist behaviour.
Meeerrrk
posted on 9/2/09 at 12:54 PM Reply With Quote
ive got a 4KAM set up (google 4KAM) their mics are espically set up for car/bike noise but the wind may be a problem. that said, the mics are remote and can be placed anywhere. Good bit of kit. need to work out how to edit video next
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
Jubal
posted on 9/2/09 at 07:04 PM Reply With Quote
Here's a sample from my camera at proper res. It's compressed (MPEG2) but it's still very close to the quality straight from the cam. Be interested in any feedback compared with a DVR.
http://www.filefactory.com/file/afhfg69/n/smaller_mpg
Meeerrrk
posted on 9/2/09 at 07:37 PM Reply With Quote
just downloading it now. 4kams DVR is good value @ £169
Meeerrrk
posted on 9/2/09 at 07:41 PM Reply With Quote
seems good, i would say around the same as a solid state DVR. i would have thought the camera has more to do with it?
Where do you place your mic please?
Jubal
posted on 9/2/09 at 08:18 PM Reply With Quote
The compression has an impact too. I put the mic in the passenger footwell. Out of the wind.
Meeerrrk
posted on 9/2/09 at 09:09 PM Reply With Quote
thats what i was planning on trying, basically under the dash somewhere. Looking at your vid again i rate the quality as very good, you could do a lot worse!
austin man
posted on 10/2/09 at 11:45 PM Reply With Quote
my camera has the mic in the bullet camera not seperate this is why I have a noise issue tried everything to reduce the noise, the camera body increases the noise levels, I will be disconecting the mic and making it seperate from the camera to get around the problem
mark chandler
posted on 11/2/09 at 11:45 PM Reply With Quote
Thanks Jubal
That's a nice clear image, 520 lines does it for me, I suspect its better than my DVR recorder.
Cheers Mark
New Topic New Reply
