New Topic New Reply
Author: Subject: I've started so ....
posted on 11/3/09 at 07:43 AM Reply With Quote
.... I may or may not finish.
Spent last evening to get to this point:
Everything came undone nicely
discovered that my head is leaded (I can feel big ridge in exhaust ports that would be the inserts)
.... but already having second thoughts as remembered the supercharging article.
Maybe I should opt for a 1/2 way house, instead of taller 1660 engine transplant, up the level of current engine:
such as:
- larger valve head and ported
- more whacky camshaft (dunno what's in at the mo'
- 1100 pistons?
- vernier timing
- or maybe attempt the supercharger?
- bore out block to 1430???
speedyxjs
posted on 11/3/09 at 07:45 AM Reply With Quote
Hypercharge it
omega0684
posted on 11/3/09 at 07:57 AM Reply With Quote
whats your budget?
posted on 11/3/09 at 08:05 AM Reply With Quote
In theory I have all the bits already so no need to spend any more but I would be looking at:
1. overhaul of head with unleaded inserts and larger inlet valves - that would be £ 300 ish.
2. duplex vernier timing gear £ 100
3. 1600 inlet manifold £ 100 (if I go to taller block)
oooh, it soon mounts up but that is not a prob; I guess it is gonna be in region of £ 500 - 700.
and no, no zetec or bike engine suggestions.
I have various zetec/engine & engine bits that I either am gonna fit or else sell as these are just taking up space.
Mr Whippy
posted on 11/3/09 at 09:04 AM Reply With Quote
£500-700
you could buy a larger second hand engine for far less
Dangle_kt
why not fit the 1600 engine and use the money you are saving on cams etc to buy a bespoke exhaust? It will be cheaper I bet and then you arn't throwing away all that hard work when you decide you want the bigger engine after all.
Mr Whippy
posted on 11/3/09 at 09:36 AM Reply With Quote
I have a very nice 2.8 v6 in the garage......
posted on 11/3/09 at 09:42 AM Reply With Quote
thanks but no.
The plan is to reduce the number of Ford engines in my collection not increase them!
posted on 11/3/09 at 11:42 AM Reply With Quote
Originally posted by 02GF74
.discovered that my head is leaded (I can feel big ridge in exhaust ports that would be the inserts)
Don't assume this means they have inserts. You get a ridge formed on normal heads when a cutter is used to open out the valve throats.
posted on 11/3/09 at 08:25 PM Reply With Quote
If your thinking of fitting a supercharger as in the PPC article it may be better to fit it to the taller 1600 block due to clearances
mangogrooveworkshop
posted on 11/3/09 at 09:08 PM Reply With Quote
we may need to borrow that
iank
posted on 11/3/09 at 09:50 PM Reply With Quote
Got an oil tanker you need to stop?
Anonymous
New Topic New Reply
