New Topic New Reply
Author: Subject: Nothing New Part 2.....
flak monkey
posted on 17/2/04 at 03:08 PM Reply With Quote
A while ago I posted my 3D CAD drawing I had done of the chassis. Now it is finished (until i can work out how to add in a couple of bits ) So i thought i would share the new one again (Im not trying to get my post count up ).
Let me know what you think, and if anybody else is working on the 3D models it would be good to see them.
Sera
http://www.motosera.com
posted on 17/2/04 at 03:43 PM Reply With Quote
The front of the gearbox tunnel looks a bit weak. I think it needs the two struts between the front of the floor and the battery shelf to finish off the triangulation in that area after the middle of the bottom rail has been cut out.
yours, Pete.
GO
posted on 17/2/04 at 04:13 PM Reply With Quote
Also to increase strength at the front stick an extra triangulation in between the FU bars from next to the bottom front wishbone mount to above the top rear wishbones mount.
flak monkey
posted on 17/2/04 at 04:21 PM Reply With Quote
Thanks guys like i say I know there are some bits missing, like some triangulation at the front. Unfortunately i cant work out how to create the workplane to put them in at the moment
Will sort it
Sera
ed_crouch
posted on 17/2/04 at 04:50 PM Reply With Quote
Wot software are you using??
In Solidworks, you can create a plane at an angle to a line on an existing one, do a cross section sketch on the plane, and then extrude it up. Create some more planes at the ends of the tube, and chamfer it!
Sorted.
Ed.
P.S. it gets a bit trickier to make chamfer planes at the ends of round tube, cos there isnt a planar edge to relate the new plane to. A tangential relation might do the trick??
Of course, if youre not using solidworks, this probably makes no sense at all.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
flak monkey
posted on 17/2/04 at 05:34 PM Reply With Quote
Thanks Ed
Right i think i have got that figured
See new pic have put in more triangulation at the front, and the uprights around the trans tunnel.
[Edited on 17/2/04 by flak monkey] Rescued attachment 3d Chassis postable.jpg
Sera
posted on 18/2/04 at 09:22 AM Reply With Quote
looks nice david! you could further strengthen the end of the foot well by welding steel sheets onto the end, the passanger one wouldnt need any holes so this is quite easy, and the o/s would only need a few for the controls to go thru. should stop a lot of possible flex though.
flak monkey
posted on 18/2/04 at 10:30 AM Reply With Quote
And Another One!!
Thanks Joel I have seen several (well ok most) people have welded in plates, stops all the crap coming into the car too!
Right...now I've just got to make the damn thing...easier said than done at the moment!
Sera
New Topic New Reply
