stevegough
posted on 29/3/09 at 12:43 PM |
Garage roof
Anybody had issues with garage roof (corrugated 'tin' causing megga - condensation problems especially in cold weather?
I have tried allsorts - but have now suceeded in curing it for good - see photo! the downside was the cost £1200 - but it is a big area (45 sq m)
![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif)
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
blakep82
posted on 29/3/09 at 12:44 PM |
what is it?
________________________
tomprescott
posted on 29/3/09 at 12:46 PM |
Is it a dehumidifer? Or a heater of some sort?
Guinness
posted on 29/3/09 at 12:50 PM |
I think that is a garage door opener!
I guess Steve has had his roof sprayed with insulation.
Mike
fatfranky
posted on 29/3/09 at 02:59 PM |
I have the same problem with my domestic size garage.
Absolutely horific condensation when it's cold
Hope to get new garage built this year
stevegough
posted on 29/3/09 at 03:25 PM |
Sorry, Guys, been away from PC - Yes, mr guinness is right it is 'sprayfoam' insulation - I had tried spaytacking 6mm polystyrene sheets
first, but it wasn't thick enough - and it didn't cover the 'up' bits of the corrugation - hence all it did was collect the
water and channel it down onto the 4x2 wooden roof supports!
I was very pleased with the guys who came to do the spraying.......this is their website - http://www.webstersinsulation.com/home.html
They are based in Doncaster, but they do jobs all over the country.
I now can leave stuff out in my garage without it ending up in a puddle!
Regards
[Edited on 29/3/09 by stevegough]
Luego Locost C20XE.
40inches
posted on 2/4/09 at 09:15 AM |
I replaced the corrugated sheets on my roof with triple glazed poly sheets (as per conservatory) no condensation, no need for lights, even in the
winter (except at night ) Cost around £450 including roofing bars etc; for 28 square metre roof. I also dry lined the walls with battens and plaster
board that made a huge difference to the temperature and condensation.
stevegough
posted on 2/4/09 at 08:58 PM |
There is very little framework on my roof to start with - it is just RSJs with 4x2 'battening on top - most of the strength is in the
corrugations of the roof sheets - I would have to have started with a complete new framework, and I got a bigger 'un than you! - it would
probably have cost 1200 - 1500 by the time I had finished.
It was also sooo easy - they did it in less than 3 hours.
Having said that, polycarbonate sheeting wasn't something I had thought about - and not needing 5 striplights on would have saved me a bit,
too.
![](/images//smilies/sad.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/sad.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/sad.gif)
Luego Locost C20XE.
