Miks15
posted on 27/4/09 at 03:18 PM |
Fuel Tank Help
Ive decided to make my own steel fuel tank instead of splashing out on an ally one.
Couple of quick questions:
Im using a GSXR 600 in tank fuel pump. Do i need to build a box type thing under the tank for it to sit in or can it be mounted flush to the bottom?
(hope you understand what i mean)
If i do how deep does it need to be?
Secondly do i need to coat the inside of the tank with anything or can it be left as bare steel?
Mikkel
bilbo
posted on 27/4/09 at 03:47 PM |
quote: Originally posted by Paul TigerB6
You'll have fun passing IVA if you make your own tank then!! Best to have a look at the IVA draft manual if you intend to proceed and wish to
get road legal
What's the issue here? I've read through the IVA manual on this before, and I've just checked again. There is an issue for plastic
tanks and tanks for gaseous fuel, but I can't see anything about why you can't make your own for liquid fuel, provided it is in compliance
with the reasonable standards listed (e.g. it doesn't leak etc).
Maybe I'm missing something?
Edited to say, I see you checked as well
Must have been something they dropped before the final version - thankfully.
[Edited on 27/4/09 by bilbo]
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
blakep82
posted on 27/4/09 at 03:49 PM |
metal tanks don't need any approval markings for IVA, and are deemed passable, as long as they're no leaks. so steel is no problem at
all.
keep an eye on ebay though, i've seen some nice ally ones turn up cheap from time to time
________________________
posted on 27/4/09 at 03:53 PM |
No idea on the pump Q, but there's no need to coat the inside of the tank - tin top makers certainly don't spend time and effort (money)
doing it. I'd paint the outside obviously - or you could have the whole thing galvanised I suppose.
Miks15
posted on 27/4/09 at 04:07 PM |
You scared me there at first paul!
Nick: Thanks thats one less thing then, i assume rust isnt a problem then?
Anyone else know anything about the box around the pump? ( i assume if it needs one its only to keep petrol around the pump at all times?
Miks15
posted on 27/4/09 at 05:01 PM |
Ahh right, So it doesnt really need to be too deep either then? Just to have a small pool of fuel constantly around the pump.
Should be ok then, Thanks Paul
