New Topic New Reply
Author: Subject: Locost motorhome
MK9R
posted on 20/5/09 at 01:30 PM Reply With Quote
Locost motorhome
The price of motorhomes are ridiculous, so i've toying with ideas ranging from converting a panel van, luton van and 7.5 tonner. Then i thought, i wonder if anyone has done something like this:-
vanavan
vanavan
(sorry for the very limited art work!!)
A luton van chassis with a caravan chopped and fitted, or as i like to call it a Vanavan
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 20/5/09 at 01:32 PM Reply With Quote
There used to be one near me around 25 years ago. Looked quite cool in a weird sort of way.
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
balidey
posted on 20/5/09 at 01:37 PM Reply With Quote
When you've finished making it will you come and tarmac my drive?
(yes it 'does' look a bit pikey )
Jasongray5
posted on 20/5/09 at 01:38 PM Reply With Quote
Keep the tipping mechanism. Then if you had teenagers who were problematic to get out of bed...
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
MK9R
posted on 20/5/09 at 01:41 PM Reply With Quote
PMSL!!! The pikeyness maybe the reason its not done!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
Guinness
posted on 20/5/09 at 01:53 PM Reply With Quote
Love it! You could have a range of interchangable backs for different missions!
Mike
speedyxjs
posted on 20/5/09 at 01:56 PM Reply With Quote
I like it
Mr Whippy
posted on 20/5/09 at 01:58 PM Reply With Quote
a bit of careful panelling plus a proper skirt round the bottom & it would look ok
Caravan skins are not what they use to be, very thin aluminium over a foam core so you might have a but of difficulty riveting to it and you can’t let any water ever get in-between the skins as then the outer bond fails and the caravan just comes apart
what about this
MK9R
posted on 20/5/09 at 02:01 PM Reply With Quote
Do panel vans have a chassis??? or just a conventional body????
Cheers Austen
RGB car number 9
www.trackace.co.uk
blakep82
posted on 20/5/09 at 02:12 PM Reply With Quote
panel van would be the best way i think. as long as you're not wanting the height of luxury, but happy with somewhere to kip. build in some bunks, bit of carpet and a window, job done
in fact, if you got a transit van for example, and got the sliding door from a tourneo (or whatever their minibus things are called) as long as they are the same (except the window) swap it over i reckon it would be pretty good!
you can get back doors with the windows too
________________________
mangogrooveworkshop
posted on 20/5/09 at 02:26 PM Reply With Quote
think i will build one just like that to see their faces
blakep82
posted on 20/5/09 at 02:58 PM Reply With Quote
i quite fancy building a beavertail out of a luton van chassis now...
MK9R
posted on 20/5/09 at 03:02 PM Reply With Quote
Thats an option i was looking at, beaver tailer for the race car to sit on and tow a caravan, rather than the other way round
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 20/5/09 at 03:03 PM Reply With Quote
Or buy a luton with a tail lifet, sack the box off and use the tail lift to get the car on the back
Cheers Austen
RGB car number 9
www.trackace.co.uk
blakep82
posted on 20/5/09 at 03:29 PM Reply With Quote
will the tail lift off a luton be up to lifting a car?
GregSL75
posted on 20/5/09 at 03:39 PM Reply With Quote
http://www.sbmcc.co.uk/
There's been a few comedy caravan-on-a-flatbed type campers on Ebay...
2.0 XE on GSXR TBs and Megasquirt
Daddylonglegs
posted on 20/5/09 at 03:46 PM Reply With Quote
Starcraft
Starcraft
Mk4/5 Cortina-based Starcraft
Benzine
posted on 20/5/09 at 03:47 PM Reply With Quote
Yeah sbmcc is worth a look ^
I've just about finished converting a Bedford TK horsebox into a motorhome. I didn't like the white plastic motorhomes (or the price tags! ) so decided to 'go locost'. Basically everything is wood and it's like a compact swiss chalet on wheels ^__^ Double bed above the cab, shower/toilet at the back, sofa, wood stove, solar power. No road tax, cheap to buy, fun to drive, interior is gorgeous (imho )
[Edited on 20/5/09 by Benzine]
Daddylonglegs
posted on 20/5/09 at 03:48 PM Reply With Quote
Want to be careful he doesn't check out your garage contents while he's at it
zilspeed
posted on 20/5/09 at 04:28 PM Reply With Quote
Friend of mine did that very thing.
Took a f**ing massive caravan with some front damage.
Repaired the damage and grafted it onto a Transit chassis.
The transit chassis was lengthened and the back of the cab cut away and blended into the caravan.
He then built belly lockers to house the genny and tanks.
This tows a 4 wheeled tipping Brian James with the Fisher Fury on it.
Uses it for away weekends doing the sprints and hillclimbs.
It needn't always be a lash up of an idea when done properly...
mr henderson
posted on 20/5/09 at 04:29 PM Reply With Quote
Interesting idea, but most tail lifts use the upright bits at each side of the rear of the Luton body, and don't extend back far enough to put a car on.
I've thought about this a lot, and haven't come up with the definitive answer yet.
John
MK9R
posted on 21/5/09 at 06:47 AM Reply With Quote
John
There are loads of people out there using the tail lift, including a guy who races in RGB with me who has a 7.5 ton lorry to carry the car in and has a living area aswell. This is alos for sale on piston heads, i was very tempted!
http://www.chriswilson.tv/more814/814.html
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 21/5/09 at 06:54 AM Reply With Quote
PICTURES?????
Cheers Austen
RGB car number 9
www.trackace.co.uk
posted on 21/5/09 at 04:45 PM Reply With Quote
That looks quite scary to me, check out the hooks for the chains at the end of the main tail lift section, wouldn't have to bend much for the chain to fall off.
Schrodinger
posted on 22/5/09 at 10:10 AM Reply With Quote
If you go down the conversion of a panel van route you need to bear in mind the deffinitons of what a motorhome is for insurance purposes as it may just still be a van in their view.
Try looking here http://www.diy-motorhome.co.uk/
Keith
Aviemore
New Topic New Reply
