New Topic New Reply
Author: Subject: who's any good at maths
piddy
posted on 25/5/09 at 03:47 PM Reply With Quote
I'm trying to work out how much fuel is in my tank,when it says it empty.
The tank is 170 mm deep and 685mm wide the level of the fuel is 65mm high.
I'm thinking I should multiple 170 by 685 by 65 but how do you then convert this figure to litres?
posted on 25/5/09 at 03:50 PM Reply With Quote
1 litre = 1000 cc, i.e. multiply all your numbers together to get the volume in cubic centimetres, then divide by 1000.
Simples! <chk!)
Macbeast
posted on 25/5/09 at 03:51 PM Reply With Quote
7.569 L (I think )
His numbers are in mm so first divide each by 10
[Edited on 25/5/09 by Macbeast]
prawnabie
posted on 25/5/09 at 03:52 PM Reply With Quote
17cm x 6.5cm = 110.5cm2
110.5cm2 x 68.5cm = 7569.26cm3
or 7.569 litres
Just try converting measurements in inches into UK gallons!
mcerd1
posted on 25/5/09 at 04:08 PM Reply With Quote
thats easy
1" = 25.4mm
and
1 UK Gal. = 4564 cc
or is that cheating
posted on 25/5/09 at 04:21 PM Reply With Quote
7.569 LTS is about 1 1/2 gallons , suspect someones maths are wrong.
prawnabie
posted on 25/5/09 at 04:22 PM Reply With Quote
Its not a full tank, only whats remaining in tank when gauge shows empty.
[Edited on 25/5/09 by prawnabie]
scudderfish
posted on 25/5/09 at 04:24 PM Reply With Quote
http://tinyurl.com/oj9934
or in gallons
http://tinyurl.com/q7r6oa
prawnabie
posted on 25/5/09 at 05:42 PM Reply With Quote
see 7 posts above for the same answer
posted on 25/5/09 at 05:43 PM Reply With Quote
Must be correct then!
piddy
posted on 25/5/09 at 07:29 PM Reply With Quote
Thanks chaps. I had worked it out as 7569250 so thought it must be 7.5 ltrs or 3/4ltr. I was sure it was more than 3/4 but didn't think there was 7.5. My tank must be bigger than I originally thought.
Ninehigh
posted on 25/5/09 at 09:15 PM Reply With Quote
When it's empty there's no fuel in it...
stevegough
posted on 2/6/09 at 08:54 PM Reply With Quote
I make it 762.4 gallons correct to a tolerance of + or - 98% plus vat plus delivery.
[Edited on 2/6/09 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
New Topic New Reply
