New Topic New Reply
Author: Subject: bike fuel pump
Miks15
posted on 26/5/09 at 08:53 AM Reply With Quote
bike fuel pump
Hi all,
I bought a fuel pump off a GSXR 600 SRAD to go with my carbs, but the fuel pump has two outlets on it.
Does anyone know why theres 2 and which ones for what?
This is what my pump looks like and you can see an 8mm outlet and a 6mm outlet below it.
Mikkel
tilly819
posted on 26/5/09 at 09:05 AM Reply With Quote
Could one be the return?
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
matt_gsxr
posted on 26/5/09 at 09:10 AM Reply With Quote
The carbed GSXR600 didn't have a fuel pump!
Actually I don't think any carbed suzukis had fuel pumps (taking cover as I say this). So the only suzuki fuel pumps will be high pressure ones, and 45psi into your carbs isn't going to be very good.
www.alphasports.com is my source of information.
Do you have a part number (normally on a sticker on the underside of the unit), you can google suzuki part numbers and all becomes clear.
Matt
twybrow
posted on 26/5/09 at 09:19 AM Reply With Quote
It looks like an injection pump to me....
Miks15
posted on 26/5/09 at 09:49 AM Reply With Quote
that was the fear...
So a new fuel pump then?
Would the fuel pump off any other carbed 600 be about right?
Miks15
posted on 26/5/09 at 10:35 AM Reply With Quote
just been looking at www.alphasports.com and it looks like the SRAD's did have a fuel pump... there are no diagrams for it, but if you look at the tank diagram on the 97-00 models there is a fuel pump gasket that looks identical to mine.
Is there anyway of testing my pump, like submersing it in water and running it?
Is it possible that the smaller outlet is a breather?
will121
posted on 26/5/09 at 02:41 PM Reply With Quote
the carbed 600 SRad model did have a fuel pump in the tank like you have, there is supposidly a free 600 srad workshop manual on line as link which might help
600 srad work shop manual link
cosmick
posted on 26/5/09 at 04:34 PM Reply With Quote
this is the correct fuel pump for a GSX R600 Carbed version and they do run a fuel pump. the extra connection is a vacuum feed which comes off one cylinder to open and close the pump when the engine is running. This prevents flooding when the engine is switched off. please read my reply on your later post.
New Topic New Reply
