alistairolsen
posted on 27/5/09 at 02:38 PM |
CXR and Pro Race owners, I need a favour
Can someone with 6x13 CXRs, and someone with pro race 1 or 2's measure the diameter of the inside of the wheel level with the hub mounting face.
Could you then post the offset, the measured diameter and perhaps a photo of the inside of the rim for me?
dan__wright
posted on 27/5/09 at 02:57 PM |
i should be home at the weekend so will get you some measurements then.
pro race 1.2's
if you asking what i think you are, i had to change to fiesta front disks (turned down hub) and then move the calipers in a few mm.
speed8
posted on 27/5/09 at 03:28 PM |
and i think i know the question too...
i have sierra rear calipers. they fit if you take off one turn on the handbrake spring.
i can get you a photo tomorrow probably once i get the car back over the pit.
alistairolsen
posted on 27/5/09 at 03:53 PM |
close, but no cigar!
Im trying to fit mazda uprights with 254mm vents and wilwood superlites, so I figure no one would know if that fitted or not, hence the
measurements.
Rear will be on 231mm solid disks and more than likely 7 inch rims so shouldnt be an issue.
Dan, if you could get measurements at the weekend that would be great!
StevieB
posted on 27/5/09 at 04:57 PM |
How do you mean take a turn off the spring?
I want to go with CXR's on my Indy eventually, so am very interested in whether they'll fit or not.
