New Topic New Reply
Author: Subject: engine swap - think I'm gonn bail out ....
posted on 16/6/09 at 08:15 PM Reply With Quote
trial fitted carbs - filter backplate on rear one is very close to the brake master - if I am lucky, there'll be 5 mm clearance at most..... but then the turret on front carb is up against bonnet - to fix that I owuld need to lower engine.
cannot see how I can do that easily ... so current thought is to get the 1300 bored out to max, fit 1100 pistons and be done with it.
with a uprated cam, bigger valve head,. should see some increase.
really wish I had left it alone now, especailly as have missed most of the summere. arse.
MakeEverything
posted on 16/6/09 at 08:24 PM Reply With Quote
Which Engine?
Kindest Regards,
Richard.
speedyxjs
posted on 17/6/09 at 06:05 AM Reply With Quote
A bonnet bulge should help the bonnet clear the turret on the front.
omega0684
posted on 17/6/09 at 08:55 AM Reply With Quote
5mm is a massive gap, some of the stuff in my engine bay pass each other by literally mm's,
cut a hole in the bonnet to accommodate the filter, plus you will then have a cold air feed into the carbs
posted on 17/6/09 at 09:22 AM Reply With Quote
some answers. 1300 crossflow replaced by 1660.
don't want bonnet bulges if I can help it.
the 5 mm is guesstimate. engine is firmly in place but with a T shirt for head gasket (truly locost! ) and head lying on top of that, not bolted. the weight of the carbs/manifold (twin 40s) moves them so it is not possible to say what their final position is.
bloody turret on carb (choke piston) is right up against the bonnet - the brass nut has already been filed down.
I'm just getting fed up of this - I would need much more stripping down - to see what is going on insdie the trnasmission tunnel to see if I can alter engine positon - which would mean adjustments to my engine mounts - more cutting and welding or cut the chassis but that is going beyond point of no retun type of situaiton and I won't know if that will help.
the lowest point is the gearbox bell housing and I want to keep that in same poisiton and rotat the engine gearbox to lower the engine front - but that may put an unfavourable angle on the prop.
posted on 17/6/09 at 09:36 AM Reply With Quote
If the engine is tilting up toward the front then you may already have an unfavourable angle on the front UJ. I wouldn't worry about that too much anyway, the angle will be very small.
Get the car jacked up as high as possible, put it on axle stands and get underneath to see what is actually tilting the engine up. The fix might be as simple as a few washers on the gearbox mounting to raise it up.
posted on 17/6/09 at 07:32 PM Reply With Quote
Your better off with a slight angle for the prop UJs than being in line.
HOL
posted on 18/6/09 at 08:56 AM Reply With Quote
The 1600 engine sits an Inch and a bit higher than the 1300. nothing more. Basically, half the extra throw of the crank.
You can physically see the difference by looking directly at the front above where the waterpump is.
For such a small amout of fettling, the gains WILL be significant.
posted on 18/6/09 at 10:08 AM Reply With Quote
it is nearer to 30 mm - you forgot to take into account the longer con rods.
doesn't sound like much but the 1300 was quite tight for space.
gonna have to remove the tunnel top and see whatTF is going on.
posted on 18/6/09 at 11:29 AM Reply With Quote
To be fair that is an inch and a bit
I know how depressing stuff like this gets though, you can work for ages and then come up against a real PITA problem like this.
New Topic New Reply
