AdrianH
posted on 18/6/09 at 05:53 PM |
Can anyone guess the answer to this email to DVLA Headquarters
Could you please help clear up an uncertainty for me. Long explanation sorry!
I am building a kit car from scratch that will have to pass the new IVA test. In the IVA manual the rules state it must have a manufacturers plate
with the manufacturers name and a vehicle identity number.
That both the name and VIN can only consist of capital letters and numerals and that the VIN must consist of 17 characters.
For the name I can use my own name, so no issue with that, but there are no rules laid out for the VIN number other then the above use of capital
letters ,numerals and 17 characters long.
A fellow builder used a mixture of his initials, date of birth, completion date, etc. to make up a unique VIN number. This passed the VOSA paperwork,
the vehicle passed SVA/IVA Inspection, had a MAC form issued etc.
At the next stage of DVLA Inspection to obtain registration documents, where the pass forms are checked against the VIN number. The VIN was rejected
as it did not conform to a standard numbering scheme for cars manufactured in the UK! The builder then had to change the VIN and chassis number and
have the VOSA forms re-issued with the new number before once again applying to the local DVLA office for registration documents.
So please, what are the rules on creating ones own VIN number, as other builders are telling me the only rules are the number must be unique but can
be made up of any letters/numbers. I would hate to get so far down the line to be set back on this at a local office?
My build is nearing completion and need to add the VIN number soon.
Many thanks
Adrian
Just checked something with CS and I got the bit wrong about VOSA redoing the forms, DVLA just issued a different number.
[Edited on 18-6-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
mad4x4
posted on 18/6/09 at 06:02 PM |
you should be able to apply to DVLA to get them to issue a VIn number
Flamez
posted on 18/6/09 at 06:03 PM |
submit a number for consideration?????
I made my own up and admitted it and the inspector was ok.
my build mac1motorsports
Paul (Notts)
posted on 18/6/09 at 06:07 PM |
The simple answer is – get the dvla to issue you with a vin. It saves a lot of potential hassle.
If you make up your own then there are certain letters , numbers that it can not contain.
I made my own up with the correct letters and numbers BUT was told by the local dvla it was not acceptable as it did not comply to European standards
for cars manufactured in the European community. I challenged this as the legislation is worded “ car manufactured for Sale “ as my car was not
manufactured for sale then these rules did not apply.
Swansea did not accept my challenge BUT decided they would accept my VIN as a simple way to resolve the issue ( Friday). They sent someone out on a
Sunday to inspect the car and had docs ready by Monday lunch.
Paul
COREdevelopments
posted on 18/6/09 at 06:08 PM |
"I'm the only one here who will be giving out chassis numbers hahahaha!!!" thats the reply i had from swansea
BTW Flamez your car looks awesome. aint seen it blasting about yet though. il keep an eye out.
Rob
[Edited on 18/6/09 by COREdevelopments]
MautoK
I wrote to the local DVLA (Exeter) proposing the VIN I had concocted. They wrote back, quoting the number and said it was acceptable.
John.
Guinness
posted on 18/6/09 at 06:12 PM |
I can't tell you what the answer will be,
but I can promise you one thing,
it'll be a different answer next time you ask.
In fact, can we have 10 people send the same email / letter in and see what the average response is?
Mike
James
posted on 18/6/09 at 06:17 PM |
My very first contact with DVLA was a faxed letter to local office along the lines of:
"I've built an amateur built vehicle. I want to use chassis number: XXXXXXXXXX is this ok? Please contact me and send me the relevent
forms.
My chassis number was fine, the car was inspected before SVA and the car was registered and I had tax and plates the day of my SVA pass"
I know that my case worker was considered the 'expert' and other DVLA workers would contact her from around the country for how to do it.
Maybe just dropped lucky!
JAmes
- Muhammad Ali
mad-butcher
posted on 18/6/09 at 06:18 PM |
Depends on your local office (chester)I made mine up and it was accepted. the same thing/problem also applies to registration as regards to Q plate or
age related
no consistency
tony
James
The fact you can import a car from any country with any number and structure and register means the process is in place for it to be fine.
James
- Muhammad Ali
alistairolsen
posted on 18/6/09 at 06:20 PM |
Id imagine it wont be able to contain zero, i, z, u, o, etc in the same way as number plates?
AdrianH
posted on 18/6/09 at 06:24 PM |
The response is: -...
You will need to contact the DVLA Local Office that you will be making your application to register the vehicle to regarding the specific make up of
the VIN number.
So no central policy. I will be in contact with my local office tomorrow. I just want a smooth process if such exists?
Adrian
stevegough
posted on 18/6/09 at 06:42 PM |
Hi, Adrian - are you dealing with the preston office? If so, let me (and everone else) know the outcome as that is my local VLO.
Cheers, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
kendo
posted on 18/6/09 at 07:43 PM |
I found on the DVLA site an explanation of how the VIN number can be constructed. For a UK car it must start with an 'S' be between 9 and
17 digits contain no 1's o's or 0's and the last six digits must be numbers.
That said I've not got mine through DVLA yet.
Answer me this though, why would a national organisation not have uniform and centralised policies and proceedures?
ReMan
posted on 18/6/09 at 08:13 PM |
"Answer me this though, why would a national organisation not have uniform and centralised policies and proceedures?"
Because they are a national organisation?
Because they are a bunch of half wit cocks?
Because they are goverment run?
More?
zoom
posted on 18/6/09 at 08:14 PM |
I'm going through this at the moment, My home made vin was accepted by vosa, by my insurance and also noted down during the built up inspection,
but dvla are refusing to accept it and insisiting I change it to one they issue. Tomorrow I will have the vin changed and have the paperwork stamped
by the garage who stamp it to prove to dvla its been changed and only then will they issue a reg.
Just ask for a vin from them when you apply with your v55/5 form and yoou can't go wrong. (maybe)
Oh its been 7 weeks for them even to reply to my application then 3 weeks to get a bui and then 2 weeks later they want the vin changed.
![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
mycar
mybuildsite
AdrianH
posted on 18/6/09 at 09:21 PM |
I am planning to speak with, or try to the Preston Office tomorrow.
I want the VIN number before going for the registration forms if possible as I would like to have some form of insurance on my car for the last part
of the build stage, and would like to think a chassis number is better then using an engine number. It also give me chance to have plates made and
the number stamped into the chassis or if permissable on a plate welded onto the chassis.
I will post in this thread how I get on if a make any headway.
Adrian
AdrianH
posted on 19/6/09 at 09:18 PM |
What a frustrating day it has been today, Swansea do not give emails or phone numbers for the local office, so had to discuss with someone at Swansea.
Did not get put through to Preston either.
Said I had to write or visit the office to get the forms and they are only open Monday to Friday 9 to 5.
Luckily I was passing on business so used a bit of my own time to call in, explained home build and own chassis so no manufacturers VIN number. Told
that they will issue a VIN number after the car has been inspected and it has to be a complete car before they inspect.
I explained about wanting insurance on a VIN number as I near completion as I could not do it on any registration number.
When asked about donor V5, yes I have.
Receipts yes I have,
Build proof, yes I have.
I came away with a V627/1 to complete and a V55/5. I am not going to complete them yet as I will be getting a call from their Kit car man on Monday
as he was on holiday today.
The nice lady I dealt with was polite and tried to be as helpful as possible, could also understand my frustration I think and did say it was a long
process and a bit of a catch 22 situation.
So if I understand it all.
1) Get very near end of build
2) Apply for VIN and complete V627/1 and V55/5
3) Get car inspected, this may happen at build site?
4) Provide all documentation, receipts, build pictures, donor V5 etc.
5) Get issued a VIN
6) Stick on car and pass IVA
7) Take MAC to DVLA
8) Get registration number as car has already been inspected
9) Produce Insurance certificate and get Tax disc
10 ) Walk out with big grin.
That would be nice if it went like that wouldn't it?
Adrian
