jpindy3
| posted on 22/6/09 at 07:54 PM |
just some driving a kitcar Q
right when driving and cornaring hard my prop makes a tinging noise it sounds like there is something hitting it,but i have looked and its all clear
around the prop,
so im a bit baffaled?????
fuel filter, i have 2 the one next to the carbs,somtimes after driving i look at it and its empty? some other times its
its full?
i have got fuel in the tank, its a bike fuel pump as i have zx9r carbs,also i have a pressure reg,thats set at 3psi.
thanks
flak monkey
| posted on 22/6/09 at 07:58 PM |
Fuel filters rarely sit full of fuel so I wouldnt worry about that.
The prop is probably rubbing on something as the engine and gearbox will move under hard cornering. My gearbox clouts the chassis on occasion and is
kind of the limiting thing which stops the prop hitting it!
Sera
http://www.motosera.com
pewe
| posted on 22/6/09 at 08:05 PM |
Check that the cups on your UJs aren't rotating i.e. knackered.
I've just cured a similar noise on the front of mine , originally thinkiing it was the UJ's (turned out they were knackered but not the
cause of the noise).
After taking the front wheel bearings apart a number of times I discovered that it was the alternator body kissing the aluminium side panel on right
hand corners.
Have you taken a passenger (preferably one with mechanical sympathy - if you get my drift!) out to help you narrow down where the noise is coming
from?
Cheers, Pewe
PS what about prop or driveshaft hitting a zip-tie or similar?
[Edited on 22/6/09 by pewe]
jpindy3
| posted on 22/6/09 at 08:08 PM |
ahha
i just thort when my tank is full the pressure keeps fuel in the filter as the fuel is used and the leval reachs the filter hight or below when the
engine is off the filter is empty,
god i suprise myself,there is somthing there somwhere somtimes
Steve G
| posted on 22/6/09 at 08:10 PM |
Bike fuel pumps dont need a regulator - they self regulate themselves. All the ones commonly used do anyway so not aware of any that dont. So long as
you get fuel through when you then as said i wouldnt worry too much.
Are you sure its the prop thats hitting?? May be worth having a good look at your gearbox and maybe even engine mounts to see if they are stiff
enough. 160kg with sideways force on it will certainly move a soft rubber mount a fair way
jpindy3
| posted on 22/6/09 at 08:12 PM |
hand corners.
from?
Cheers, Pewe
thats it alternater,all the other stuff new,and the alt is clse to a rail
thanks
matty_64
| posted on 22/6/09 at 08:33 PM |
ill second the check your uj comment.i had the tinkle tinkle noise,found a bit of play and this was why.new joint is only a tenner and fairly easy to
fit
jacko
| posted on 22/6/09 at 09:58 PM |
This is what i made to stop the engine moving side ways
  engine mounting
Jacko
