New Topic New Reply
Author: Subject: Crossflow oil
Staple balls
posted on 4/7/09 at 11:46 AM Reply With Quote
Crossflow oil
How much do they like to have in them?
Cheers.
Steve G
posted on 4/7/09 at 12:03 PM Reply With Quote
enough to get to the max mark on the dipstick generally
nib1980
posted on 4/7/09 at 12:10 PM Reply With Quote
depnds, on if it's a new build and filter change or just a drain and replace.
Staple balls
posted on 4/7/09 at 12:11 PM Reply With Quote
Fair point, but I'm not sure how accurate the dipstick is on the sump I have.
is a drain and replace, due to sump repair.
posted on 4/7/09 at 12:42 PM Reply With Quote
Depends on type of sump -- 6.25 pints inc filter
procomp
posted on 7/7/09 at 07:05 AM Reply With Quote
HI
If the sump has been modified IE shortened it will not matter. You can still only fill it to maximum height MAX. Any higher on the dipstick and the crank will start to pick it up.
Check the dipstick though. Where the part number is on the end. If it has a AA it is for a 1300cc if it has a BA it is for a 1600cc.
Cheers Matt
New Topic New Reply
