MautoK
| posted on 16/7/09 at 09:04 PM |
Oil cooler/number plate conflict
L&G,
As this covers both transmission and bodywork I've posted here.
Just fitted an oil cooler for the autobox. Cooler is just in front of the rack:
  Cooler
The hose is 100R6, not heater hose!
I've cut air entry holes to feed the cooler:
  Air inlet
However, this conflicts with the number plate.
So I've wondered about cutting the plate so that, instead of
F576 OTA (linear)
it becomes
F576
OTA
in rectangular form.
  Exterior
The aim is to have the F576 as shown with the OTA symmetrically beneath.
Any reason I should not do this?
The other way is to mount it about 1"to 1.5" higher than is was (central). This would slightly restrict air flow to a few more rows of the
water radiator, but at least it's the less hot half of the Polo rad.
Another is to fit a stick-on plate on the leading edge of the nosecone, but are these legal in this day and age?
Any other ideas?
Thanks,
John.
graememk
| posted on 16/7/09 at 09:08 PM |
do you need one on a pinto ?
eccsmk
| posted on 16/7/09 at 09:11 PM |
thats what i was thinking
plus if you bin the mesh from your grill it will aid airflow into the engine bay and drop engine temps anyway
i may be wrong (yet again)
Guinness
It's got an auto box.
I'd just get a stick on plate, or a slightly smaller "show plate"
Mike
Steve G
| posted on 16/7/09 at 09:17 PM |
I'd also go with a smaller plate - to keep it legal though go for the smaller motorbike font size as found on certain Jap import cars at the
front.
austin man
| posted on 16/7/09 at 09:27 PM |
I didn't think cars could use smaller letters, sure they have to be a minimum size and Font ??
clairetoo
| posted on 16/7/09 at 09:30 PM |
As far as I am aware , engine type has no bearing on the need for a number plate
As suggested , I would go with a stick-on plate on top of the nosecone .
Its cuz I is blond , innit
Claire xx
Will weld for food......
MautoK
| posted on 16/7/09 at 09:45 PM |
The cooler is for the auto box fluid.
Even though there's about 2 gallons of the dreaded ATF it gets excessively hot after 15-20 miles - this was on the rather warmer days a couple
of weeks back. The box is quite a tight fit, even in the wider-than-standard tunnel AND I've fitted a guard under both the engine and autobox
sumps; so the pan doesn't get any cooling airflow.
I could fit a smaller no. plate but I think these days you have to use the standard plate/character dimensions. The only exception AFAIK is imported
cars that can't accommodate a standard plate.
John.
bimbleuk
| posted on 17/7/09 at 07:37 AM |
As a general guide you need about 1/4 the frontal area of the radiator to supply sufficient air. For this to really work you need guides to trap the
air in front of the radiator ideally. So in you case maybe simply reducing the height of the number plate a bit. Raising the mounting position
sufficiently to allow a slot to be cut in the lower edge of the nose cone will supply enough air flow for the radiator to work.
[Edited on 17-7-09 by bimbleuk]
iank
| posted on 17/7/09 at 07:47 AM |
Correct, imports are officially allowed smaller plates/letters but kits aren't.
Bike plate on a car isn't legal I'm afraid.
Don't think the square plates are legal on the front only the rear, but I doubt your average copper would know for sure.
Anonymous
MautoK
| posted on 17/7/09 at 12:41 PM |
Thanks for all your comments.
I think I'll go for the simple solution and mount the plate centrally, just a bit higher than previously.
morcus
| posted on 17/7/09 at 01:54 PM |
You could build a support arm and mount it how it is in you picture, though you'd probably want to reinforce it so it doesn't break
off.
Are Sticker number plates legal?
MautoK
| posted on 17/7/09 at 03:49 PM |
ISTR that sticky plates aren't legal.
Anyway, it's done!
  Oil cooler fitted
The no. plate is horizontal (and the floor is!) so it shows up the 'MK' behind the grille is skew. I'd never noticed before!
I put a small deflector below the air inlet to the cooler as a persuader:
  Cooler inlet
A few more random pics taken today....
General view of the front:
  Front
View down the wider-than-standard tunnel showing the auto box:
  Auto box in tunnel
Dashboard:
  Dashboard
Now just waiting for the weather to perk up a bit and see how effective the cooler is...
| posted on 18/7/09 at 08:05 PM |
AFAIK stick on plates were never legal - just in olden times the police were more concerned in catching bank robbers than raising revenue by
targetting motororists.
The E-type was always pictured with stick on plates, (just been on the bay and of 5 e-types looked at, all are like this.
what you have done should be ok - you could trim a couple mm off the top and bottom of the plate.
I have
XXX
123Y
on front of my land rover and never had issue at MOT time.
if it were me, I would have put stick on plate on the nose cone*
* that is what I have.
[Edited on 18/7/09 by 02GF74]
