les
posted on 18/7/09 at 09:02 PM |
r1 fuel pump
Hi guys,
I have installed an r1 fuel pump on the avon (R1 Carbs) but i think
i may have killed it!!
I connected the blue and black wire from the pump to positive and the black to negative. installed the pump by mounting it on a chassis rail- but
nothing,
the pump wont run at all no matter what I try.
Is there a correct orientation for the pump? does it need priming? anything else???!!
thanks in advance
Les
bob
posted on 18/7/09 at 09:14 PM |
R1 carb external pumps self regulate,if its up to pressure it switches off,very quiet pump but you should hear some ticking while its dragging the
fuel up.
I did suck some fuel into mine to prime it before running which is probably a good idea.
All the normal stuff check live feed/fuse and earth,sadly does sound like it might be buggered though.
les
posted on 18/7/09 at 09:27 PM |
Thanks mate, i take it I got the wires the right way round?
which way up did you mount yours?
Les
bob
posted on 18/7/09 at 09:30 PM |
Les i just checked through my old build notes and yes its black/blue = plus and black = minus
The pipes on the pump are slightly different sizes, big pipe is feed in from tank and small pipe out to carbs.
james h
posted on 18/7/09 at 10:57 PM |
I find my pump fairly noisy, but you should hear it clicking when you turn on the ignition.
les
posted on 19/7/09 at 06:25 PM |
thanks guys, ill get another pump and try it.
