New Topic New Reply
Author: Subject: Anybody with a lathe?
Miks15
posted on 22/7/09 at 12:26 PM Reply With Quote
I need this making up:
Would anyone mind doing them for me, i need 2 making in brass (or anything else that wouldnt mind brake fluid running through it.
Mikkel
James
posted on 22/7/09 at 12:34 PM Reply With Quote
Flak Monkey!!!!
Be his first commision! (unless he's had others! )
He's just bought a new lathe and recently said he was up for doing work for people.
James
Mr Whippy
posted on 22/7/09 at 12:39 PM Reply With Quote
is this the same kind of thing as part 7 on this diagram?
These are universal and fit ford master cylinders too or most brake reservoir rubbers (I used then on the Falcon)
You can buy them here
Rod Ends
posted on 22/7/09 at 12:40 PM Reply With Quote
you need to put tolerances on the diagram.
Nice drawing, lot of work for a manual lathe tho, cnc would be better...
balidey
this do you?
http://cgi.ebay.co.uk/FUEL-HOSE-METAL-JOINER-REDUCER-8mm-to-6mm_W0QQcmdZViewItemQQimsfpZTL090617184002r31477QQimsxZ20090617QQitemZ200353444408QQsaleno tsupported
DarrenW
posted on 22/7/09 at 12:47 PM Reply With Quote
Give ower lad! Absolute doddle for anyone who can use a lathe and is half trained. I used to make far more complicated pieces than that when i was a lad.
flak monkey
posted on 22/7/09 at 12:49 PM Reply With Quote
I can make you a couple in aluminium if you like?
No problems
Sera
http://www.motosera.com
ashg
posted on 22/7/09 at 03:56 PM Reply With Quote
doddle to make those. i can do it if monkie man can't
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
tomprescott
posted on 22/7/09 at 07:33 PM Reply With Quote
Coozers good on a lathe, he did me a gear knob in ali, looks absolutely mint. Cheers Coozer.
DarrenW
posted on 22/7/09 at 09:27 PM Reply With Quote
I know he is. Hes a mate and ex work colleague
New Topic New Reply
