New Topic New Reply
Author: Subject: few questions
Angus180
posted on 24/7/09 at 03:35 PM Reply With Quote
few questions
hi guys just a few different questions
1. what should oil look like when i drain my catch tank?
2. where can i get a oil filter and what oil should i use for my tunned pinto i have heard pintos suffer from poor oil feed to the cams due to small oil feeds and thick oil being used.
3. how do i find out what pinto i have so i can buy the correct filter?
mookaloid
posted on 24/7/09 at 04:07 PM Reply With Quote
1. probably won't look great - might well have mayonnaise type stuff in it. this is because the hot oil mist condenses and as it cools it draws moist air in which also condenses. Nothing to worry about though.
2. get an oil filter just about anywhere I don't think they are different between the various models. I used to use a semi synthetic in mine - one suitable for older engines - not too thin.
3. Have a look on the side of the block for some large cast numbers 205, 165 or similar which will tell you which block you have.
Mark
omega0684
posted on 24/7/09 at 04:38 PM Reply With Quote
what sort of induction system are you running?
-down-draught twin choke carb
-single side-draught
-twin side-draught
-bike carbs
-ITB's
as mentioned there will be some large numbers on the side of the block 165, 200, 205 etc
what ltr is the engine?
Angus180
posted on 24/7/09 at 08:33 PM Reply With Quote
twin 45's drinks alot of fuel tho. 150bhp
my catch tank was creamy brown which i was slightly worried abou.
Angus180
posted on 24/7/09 at 09:16 PM Reply With Quote
2.0lt 205 block and lots of other numbers on the block.
New Topic New Reply
