wrigglypig
posted on 11/8/09 at 10:24 PM |
fuel pump
I have been told that the std pinto fuel pump has too much pressure for bike carbs (ZZR1100) in my case. Can anyone confirm this?? If this is the
case is a pressure regualtor an option (if so what pressure?) Failing this will any decent size bike pump fit??
Any help appreciated
posted on 11/8/09 at 10:26 PM |
IMHO it's not worth faffing around with pressure regulators. Just get a self-regulating bike pump and be done with it
Dangle_kt
posted on 12/8/09 at 05:28 AM |
Any bog engined bike pump will do, just be aware that you need different ones on carbs to injection, so make sure you pick a similar alternative. Also
remember the id of the fuel line is best the same at both ends.
