Author: Subject: mk steering rack
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
Building: built mk indy blade now got a cobra
posted on 16/8/09 at 06:11 PM Reply With Quote
mk steering rack
hi there
further my post from friday about my sva retest fail
as i have not got alot of time to sort out the steering rack problem i have on the car now which is a modified sierra one
would a mk2 escort rack fit ok without modification to an mk indy like this one from rallydesign
http://www.rallydesign.co.uk/index.php?cPath=900_1332_1331&osCsid=ch05o804ll7c3u7mmqhoqfri95
cheers stu
James
posted on 16/8/09 at 06:26 PM Reply With Quote
Not everyone reads every post on here so it might help to include the detail from that with this question.
James
mad-butcher
posted on 16/8/09 at 06:27 PM Reply With Quote
I don't think so other wise you will end up with major bump steer issues
tony
Link to original post
[Edited on 16/8/09 by mad-butcher]
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 16/8/09 at 06:32 PM Reply With Quote
ok my mk would not self center and the wheels rubbed on the front wishbones and the inspector tried to help and as he adjusted the track rod ends the tie rods unscrewed from the rack which the inspector said should not happen and it should have some sort of locking device to stop the tie rod coming of the rack
[Edited on 16/8/09 by stupott901]
James
posted on 16/8/09 at 06:33 PM Reply With Quote
Actually the joints *are* in the right place.
But the mounts are totally different.
I'd focus on sorting what you have currently.
HTH,
James
James
posted on 16/8/09 at 06:35 PM Reply With Quote
I don't think there's any locking device on my rack.
Once it's tightened up, the join between the metals is bashed with a hammer and punch to deform them both slightly and lock them together.
HTH,
James
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 16/8/09 at 06:42 PM Reply With Quote
oh ok
i did read the sierra manual and there is no mention of any locking nuts or pins
so could the inspector be wrong?
matt_claydon
posted on 16/8/09 at 06:48 PM Reply With Quote
The inspector was wrong, there is no lock pin etc on the sierra rack.
James is correct, you can see the indent where you deform the joint into when you 'hit with a big hammer'.
All you need to do is do it up triple-F tight with a big pair of Mole Grips and use a good strong threadlock/retainer and it should be fine.
[Edited on 16/8/09 by matt_claydon]
daviep
posted on 16/8/09 at 06:56 PM Reply With Quote
Don't know about the sierra rack in particular but plenty racks have the track rod fitted without a mechanical locking device, Merc Sprinter and Ford Transit off the top of my head.
I would refit the track rod using medium strength loctite and ensure it is correctly tightened.
Davie
posted on 16/8/09 at 07:00 PM Reply With Quote
Ball joint should be staked into the groove on the end of the rack but as already suggested clean , degrease and use loctite and make sure it's tight
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 16/8/09 at 07:02 PM Reply With Quote
oh ok hopefully that has saved a few quid getting a new rack
the only problem will be convincing the inspector as he was not very open discussion
and also sort out the self centering ahhhh
Mark G
posted on 16/8/09 at 07:06 PM Reply With Quote
Stu, where in Bristol are you located? I had the same problem when I SVA'd mine. If you like I can come over to you and we'll have a go at fixing it the way I did mine without having to replace any parts.
U2U me if you like.
Mark.
posted on 16/8/09 at 07:15 PM Reply With Quote
At least he saved a potentially nasty accident; if the inner ball joint was loose in the end of the rack then normal suspension movement and steering could have gradually unscrewed it...
If there is any argument then you may be able to get written confirmation from Ford.
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 16/8/09 at 07:19 PM Reply With Quote
yes i agree he did save me a nasty accident which im grateful for im glad i did not drive it there
i was just stating that he was adament there should be a locking device there
austin man
posted on 16/8/09 at 08:44 PM Reply With Quote
use a large set of stilsons to tighten it up. some people fit valve springs to assist the self centreing this also reduce lock and would prevent the wheel rubbing
