posted on 16/9/09 at 07:00 PM |
Anyone Using Audi Power?
I'm sure I've asked this before, but can't find it in the archives (doh!).
So, if you'll indulge me...
Front engine / RWD layout - what boxes are you using?
flak monkey
posted on 16/9/09 at 07:05 PM |
What you need to know, I reckon, is what VAG cars are RWD from the factory. And find a box from one of them?
At the moment I cant think of any....not tat have proper manual gearboxes anyway.
Adaptor bellhousing?
Sera
http://www.motosera.com
zilspeed
posted on 16/9/09 at 07:09 PM |
There's a Dutch company which makes the bellhousing.
Or if you were mental you could take a longways Quattro box and weld up the centre diff to give RWD only.
Or stick it in the back of a middy.
posted on 16/9/09 at 07:12 PM |
None that I can think of either!
posted on 16/9/09 at 07:32 PM |
I remember the Dutch company from last time I asked... only did a bellhousing for a type-9 (which is a start, but I'd probably want to use a
'stronger' box... T5, etc).
There was also mention of welding up a quattro box, but research ruled that out ( too weak).
Middy is not an option!
Cheers though - you're jogging my memory!
PS - The Dutch company if anyone else is looking is here... LINKY
posted on 16/9/09 at 07:34 PM |
Maybe the question should be... can a Type 9 be 'up-rated' to take serious abuse!
Onto a new thread... ![](/images//smilies/bigsmile.gif)
flak monkey
posted on 16/9/09 at 07:39 PM |
Yes, it can indeed. Can easily be uprated to around 300bhp. The quaife will take even more.
Depends on the weight of the car though at the end of the day. I will be running a HD rated to 240bhp with a 330bhp duratec bolted to it. Hopefully it
will take the abuse!
Sera
posted on 16/9/09 at 07:44 PM |
LOL... I've jumped to my New Thread! See you there!
mangogrooveworkshop
posted on 17/9/09 at 12:05 AM |
Donkervoort do a seven with Vag power
alistairolsen
posted on 17/9/09 at 07:32 AM |
iirc the volvo 900 series diesels used a Vag engine and hence the M90 gearbox from those is a rwd box with a vag bellhousing on it.
Easier finding hens teeth however.
My Build Thread
