New Topic New Reply
Author: Subject: hot water tank fittings - help
bigbravedave
posted on 10/10/09 at 07:54 PM Reply With Quote
After several plumbing quotes to change a leaking hot water tank I thought how difficult can it be and brought a replacement and will do it tomorrow. Its in a really tight location and the current tank has elbows between the 22mm pipe and the 1" fittings. my question is how do plumbers get theses elbows to orientate so that after tightening the 90 elbow to the tank the other end of the 90 points perfectly upwards, is there a trick im missing, do they apply a load of jointing compound and undo the fitting slightly to orientate, or do they sand the mating face down so when fully tightened it points where they need it?
Im puzzled?
Macbeast
posted on 10/10/09 at 07:57 PM Reply With Quote
I think just quantities of PTFE tape and just do up reasonably tight.
watsonpj
posted on 10/10/09 at 07:58 PM Reply With Quote
Have you got the fitting only the threaded part of the fittings are normally not part of the body of the bend and therefore you can orient as you like
Pete
nib1980
posted on 10/10/09 at 07:59 PM Reply With Quote
get yourself some flexi fittings
http://www.screwfix.com/cats/101316/Plumbing/Flexible-Hoses
Confused but excited.
posted on 10/10/09 at 08:08 PM Reply With Quote
....and some Evo Stik 'Plumber's Mate'.
posted on 10/10/09 at 08:42 PM Reply With Quote
id go with PTFE, we use that to ensure outside taps point downwards
iiyama
posted on 11/10/09 at 05:38 AM Reply With Quote
15 turns of PTFE per male thread. Push fit flexi's cannot be used in certain areas. Check :-
http://www.johnguest.com/litdown.asp
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Danozeman
posted on 11/10/09 at 08:28 AM Reply With Quote
how old is the tank your replacing?
The really old tanks have a different pipe arrangement. I had that problem a couple of months back. Check your pipe sizes of the new and old tank.
Dan
eccsmk
posted on 16/10/09 at 07:40 PM Reply With Quote
is it all done now ??
just wondered how you got on ??
New Topic New Reply
