New Topic New Reply
Author: Subject: Where to get steel "cups" from.
smart51
posted on 4/11/09 at 04:16 PM Reply With Quote
I'm going to be making some chassis braces for my cappuccino. The ends need to be a bit of tube, say 28mm or bigger ID and perhaps 50mm long with a closed end, drilled to take the mounting bolt. I could make these by cutting up a tube into small bits and welding a plate on one end but if I can pick up these pieces from somewhere, It'll save me some work.
Hopefully someone on here will say "cut the ends of a widget thing, that's what you want". The best I can think of is hole saws with the teeth ground off but I think the flat bit is probably not flat enough and has rounded shoulders.
Any bright ideas?
locoboy
posted on 4/11/09 at 08:14 PM Reply With Quote
If your planning on welding these onto something else i wouldn't advocate welding anything onto hole saws.
They wil be made of high carbon steel no doubt and may not weld very well.
Locoboy
smart51
posted on 4/11/09 at 10:32 PM Reply With Quote
Useful advice. Shame as they're £3.00 each on eBay.
MikeR
posted on 5/11/09 at 08:39 AM Reply With Quote
have you phoned the metal supermarket - they're expensive but as you only buy what steel you want you can save money.
If you need someone to weld them shout and i'll have a go.
Grimsdale
any steel pipe supplier should be able to supply threaded end caps for various pipe diameters. OK you probably wont have the facilites to thread the pipe but i am sure you can still weld them on. Last lot i bought were a few quid each for approx 50mm id.
New Topic New Reply
