Author: Subject: locking bosch electronic dizzy
stretch
posted on 10/11/09 at 01:03 PM Reply With Quote
how to do it? fitting gotech management system and need to get rid of the mechanical advance the dizzy does
Chippy
posted on 10/11/09 at 11:51 PM Reply With Quote
You will need to dismantle the unit. Inside you will find two bob weights that are controlled by springs, these will need to be either removed and the advance plate spot welded to the shaft, or leave them on and spot weld them so they can't move, probably the easiest thing to do. HTH Ray
stretch
posted on 11/11/09 at 06:58 AM Reply With Quote
cool thanks, is there a howto somewhere on dismantling it?
Chippy
posted on 11/11/09 at 10:51 PM Reply With Quote
Haven't seen one, but sure there must be somewhere, have you Googled it? Usually find something on there. Cheers Ray
dave r
posted on 12/11/09 at 06:50 AM Reply With Quote
if you are talking the carbed version for a pinto, then knock out the roll pin that hold the gear wheel on, and it all falls apart once thats out
dave
stretch
posted on 13/11/09 at 10:26 AM Reply With Quote
dave
yup that worked, took out the trusty welder and welded the weighs down its locked now
up next, fitting the gotech system
