New Topic New Reply
Author: Subject: wwaaaay,,, I did it ....
posted on 17/11/09 at 08:20 PM Reply With Quote
.... remove a tyre from an alloy.
not fun, I can tell ya.
it is a two stage process -fristly use electric jig saw with the narrow big toothed blade - for cutting curvess into wood ? - to slice through each sidewall - that was easy and quick.
Hard bit, is to cut the steel wires in the bead - miust be about 10 of them so overall diamaeter about 7 mm or so. This took a fair bit of time, firstly using dremel reamer bit to remove rubber from infront of the bead, then a dremel cut off disc to slice the wires. then bundle into carrier bags and into the bin
you can hear and feel the tension released with the final wire is cut
probs not do it again.
[Edited on 17/11/09 by 02GF74]
oadamo
posted on 17/11/09 at 08:24 PM Reply With Quote
the easy way is to break the bead with a hammer, then cut around with a blade then you can just pull the side bits off by hand with out cutting them lol.
adam
[Edited on 17/11/09 by oadamo]
omega0684
posted on 17/11/09 at 08:32 PM Reply With Quote
the easy way is to take it to a garage and ask them to take the tyre off, most will do it for free! lol
blakep82
posted on 17/11/09 at 08:42 PM Reply With Quote
yep ^ seems a lot of effort for nothing. especially after all the abuse r1minimagic got the other night for suggesting it lol
________________________
adithorp
posted on 17/11/09 at 08:48 PM Reply With Quote
So how long did it take?
adrian
http://jpsc.org.uk/forum/
dhutch
posted on 17/11/09 at 08:58 PM Reply With Quote
adrian
Days!!
posted on 17/11/09 at 09:06 PM Reply With Quote
not down here in the affluent south - then they'd want a fiver for displosal.
fre tuyre removal if you buy tyres from them, which I isn't.
posted on 17/11/09 at 09:08 PM Reply With Quote
adrian
No!!! not telling as you'll
matt_gsxr
posted on 17/11/09 at 09:51 PM Reply With Quote
Oadamo is bang on. To make it easier put a bit of water and washing up liquid on the knife. It then slides round really easily.
You still have to dispose of the bits though.
Matt
speedyxjs
posted on 18/11/09 at 08:32 AM Reply With Quote
Could you not have kept the tyre and disposed of it yourself? THats what i did when i need a tyre removing. Didnt cost a penny
MK9R
posted on 18/11/09 at 09:33 AM Reply With Quote
splash of petrol and a match....
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 18/11/09 at 10:43 AM Reply With Quote
Round a Gatso for value for money...
New Topic New Reply
