stretch
posted on 27/11/09 at 08:10 AM |
crossflow efi
posted on 27/11/09 at 08:33 AM |
tell us more.
is that yours? megasquirt? what are the throttle bodies?
speedyxjs
posted on 27/11/09 at 08:37 AM |
Ooooh, shiney pics
stretch
posted on 27/11/09 at 08:38 AM |
jup its mine,
bodies are old weber 40 casings, cut off what i didnt need, turned out new tubes and trumpets, gives a 37.5mm inside diam.
intake is a JCR or something that i modified to take injectors 230cc, fuel rail we made up, FPR is bosch from bmw, TPS is from ford mondeo.
using a gotech management system. just need to finish some wiring and finish return fuel line
so hopefully saturday it should run
MikeR
posted on 27/11/09 at 08:58 AM |
How / Where did you get your manifold modified to take the fuel injectors?
If you did it yourself how hard was it? How did you do it? Did you get someone to weld the ali for you?
I keep thinking of doing the same (but keeping the 40's looking as they are for a more period look).
stretch
posted on 27/11/09 at 09:12 AM |
made it all myself
i used the sidey's intake and made little inserts, drilled out hole on the intake and had the inserts welded into it, drilled those out to 14mm
to take the injectors.
u have a very valid point for keeping them more intact - with what i've learnt i would also make them look more 'old school' - if i
had to do it again
here is the rail, i'll take pics of the intake over the weekend
[Edited on 27/11/09 by stretch]
stretch
posted on 27/11/09 at 09:14 AM |
intake before modifications
mookaloid
posted on 27/11/09 at 09:46 AM |
Nice work
posted on 27/11/09 at 11:08 AM |
How did you attach the alloy tubes to the zinc alloy carb body?
stretch
posted on 27/11/09 at 11:10 AM |
just welded it on
myeates
posted on 27/11/09 at 03:11 PM |
looks very good just got my crossflow together EFI powered wish i could weld alloy hope it runs nice
