New Topic New Reply
Author: Subject: Small screenwash bottle?
posted on 13/12/09 at 06:04 PM Reply With Quote
I'm looking for a really compact screenwash bottle with built-in pump. The smallest I've found so far is like this one:
Bott le
But it looks even this one will be a squeeze.
Does anyone know of a smaller one? I really won't need a huge volume in the Locost...
posted on 13/12/09 at 06:08 PM Reply With Quote
Looks very much like the one on my car which now lives under the boot cover as there was loads of space.
iank
posted on 13/12/09 at 06:19 PM Reply With Quote
Mini/MGB setup is pretty small and might be easier to find space for despite being an external pump setup.
MGB bottle
Bracket
External pump
Anonymous
Steve G
posted on 13/12/09 at 06:20 PM Reply With Quote
Is the bag style no use to you??
linky
posted on 13/12/09 at 06:50 PM Reply With Quote
linky
Described to me as "the colostomy bag type"!
tegwin
posted on 13/12/09 at 06:58 PM Reply With Quote
I use a 1 litre plastic drinks bottle with a ford pump glued in the bottom.... Cheap as
www.verticalhorizonsmedia.tv
StrikerChris
posted on 13/12/09 at 07:13 PM Reply With Quote
i dropped lucky with a mk1 fiesta bottle.smallest i could find in the scrapy.
dave r
posted on 13/12/09 at 08:41 PM Reply With Quote
mineis an alloy drinks bottle with a pump from something jap in it
easy fit and small
posted on 13/12/09 at 09:26 PM Reply With Quote
Those MG bits that iank suggested earlier - I presume that they lift the water out of the bottle? Most of those pumps don't like running empty, so how far could the pump be from the bottle?
iank
posted on 13/12/09 at 11:00 PM Reply With Quote
Yes it's got a non-return valve in it as well iirc.
I'd put the pump next to the bottle, but I'm not sure if there's any maximum distance requirement but 6-12inches doesn't seem to cause a problem (having had a quick look around goggle images at installations).
Anonymous
Dusty
posted on 14/12/09 at 12:15 AM Reply With Quote
IVA requires the resevoir to have a capacity of at least 1.0 litres.
posted on 14/12/09 at 11:35 AM Reply With Quote
SVA was done over 4 years ago, so that doesn't worry me at all!
New Topic New Reply
