Author: Subject: no timing marks on my pinto pully.
Angus180
posted on 26/12/09 at 07:38 PM Reply With Quote
im stuck with my pinto engine as the verina cam pully has no timing marks on it, do i try to find a original one to get it line up, im stuck. and also my motorcraft distributor has no marks on it, cash in it for anyone willing to come and help; cheers
DanP
posted on 26/12/09 at 07:47 PM Reply With Quote
tear apart a spark plug to make a piston stop and then you can draw your own timing marks on!
you drill/bash/cut/dynamite out the middle of a spark plug and fit a bolt into it, fit the plug, and turn the crank one way until pistopn stops - mark the timing wheel, turn in the other way until it stops, mark the wheel again and mid way between the two is TDC, simples!
HTH
Oops I'm a divot, sorry i didn't see the words CAM PULLEY.
Sorry!
[Edited on 26/12/09 by DanP]
mookaloid
posted on 26/12/09 at 07:54 PM Reply With Quote
have a read in the cam timing bit here under technical http://www.kentcams.com/
prawnabie
posted on 26/12/09 at 09:23 PM Reply With Quote
Remember full lift on a lobe can and TDC on a piston will "dwell" for a few degrees. If you want to set it up properly and have adjustables then you need a DTI and degree wheel to find the center of the dwell.
Shaun
[Edited on 26/12/09 by prawnabie]
