New Topic New Reply
Author: Subject: bored today
boggle
posted on 15/1/10 at 10:23 PM Reply With Quote
bored today
so i made these for my ht leads....
done from ali, but will make some plastic ones now i know they will work
u2u me for details
stuart_g
posted on 15/1/10 at 10:32 PM Reply With Quote
They're neat.
I'd keep the ali ones and not bother with plastic.
tomprescott
posted on 15/1/10 at 10:36 PM Reply With Quote
Originally posted by stuart_g
They're neat.
+1. Looks good
NigeEss
posted on 15/1/10 at 10:40 PM Reply With Quote
+2
Nice job.
posted on 15/1/10 at 11:17 PM Reply With Quote
Very trick
Is that a Lynx crossover manifold you have fitted?
ReMan
posted on 16/1/10 at 12:08 AM Reply With Quote
Originally posted by NigeEss
+2
Nice job.
+3
boggle
posted on 16/1/10 at 12:13 AM Reply With Quote
Originally posted by nick205
Very trick
i have no idea? it came with the carb on it.....
u2u me for details
speedyxjs
posted on 16/1/10 at 09:13 AM Reply With Quote
+2
Nice job.
+3
+4. May look even better if you painted them red to match the leads?
omega0684
posted on 16/1/10 at 09:14 AM Reply With Quote
can you make me some please?
adithorp
posted on 16/1/10 at 10:30 AM Reply With Quote
Very neat. Altough they look good in ally', I'd go ahead and make some out of plastic. Less likely to get the sparks arcing accross in the damp.
adrian
http://jpsc.org.uk/forum/
dlatch
posted on 16/1/10 at 10:32 AM Reply With Quote
Very trick
sure looks like it to me not seen one in years
posted on 16/1/10 at 10:54 AM Reply With Quote
hmmm, holding up high voltage wires with a metal (aluminum)? ?? not good.
you can get crosstalk when ignition leads are close together in air - air being a very good electrical insulator - so using metal is not gonna do you any favours.
real shame, as they look really nice.
..... but run the engine, if there are no problems, then leave it. If you get ignition problems, then chuck them in the bin as the first step in the diagnosis.
(Burton power do these but they appear to be bits of rubber with 4 holes in them, and presumably a split to allow insertion of lead).
you are better off using a long cable tie and 3 bits of rubber hose as separators.
make cable tie into U - put in lead - put hose over both ends of the cable tie, put next lead in and so on until last lead fitted, then do up the cable tie - obviously not refittable..
[Edited on 16/1/10 by 02GF74]
clairetoo
posted on 16/1/10 at 12:07 PM Reply With Quote
Me likey !
Why not get them annodized - that would stop any arking due to being a very good insulating layer ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 16/1/10 at 12:36 PM Reply With Quote
hmmm anodizing - not sure that would work; it certainly helps prevent corrosion but as an electrical insulator?
I reckon a high voltage spark would punch a hole in the oxide.
NASA say "We conclude that anodized aluminum, while a superb thermal control surface, is not well suited in the role of electrical insulator."
boggle
posted on 16/1/10 at 10:51 PM Reply With Quote
i did think about an arc issue when i made them, hence why i thought of plastic ones....
u2u me for details
posted on 17/1/10 at 12:09 PM Reply With Quote
^^^ as statedearlier, try running engine with them fitted and without and see if there are any problems.
you;ve made them already so have nothingto lose.
I reckon you'll be ok.
New Topic New Reply
