m8kwr
posted on 2/2/10 at 01:58 PM |
Pedal Box's - Compbrake.co.uk
I am looking for a floor mounted pedal box, to run in a single seater, with a motorbike engine - so i believe i will need a full hydraulic pedal
box.
Just been looking on the web, and found this Link
Has anyone brought from Compbrake.co.uk before, and what are there products like?
Looking on the OBP site, the comparison one is £326, well over £100 more expensive, is there any difference?
Or does anyone else know of anywhere cheaper? Always after a bargain!!!!
Richard Quinn
posted on 2/2/10 at 04:55 PM |
I bought a master cylinder from Compbrake and wasn't overly impressed with it. Threw it away and bought a Wilwood one.
procomp
posted on 3/2/10 at 09:21 AM |
Hi
Mmm check out the bias bar arrangement the pedal arrangement the pedal ratio. and the unusable master cyl's. This applies to both the comp
brake and the OBP setups. they virtually the same. You would almost think the same person was making them.
Cheers Matt
m8kwr
posted on 3/2/10 at 09:54 AM |
So what pedal box am i best looking at purchasing???
As budget is tight!
procomp
posted on 3/2/10 at 01:19 PM |
Hi
You could do a lot worse than fabricate your own made to measure built to fit the aplication. At least you wouldn't have all the compromises of
a general doesn't fit doesn't work brought one.
Cheers Matt
Bluemoon
posted on 3/2/10 at 01:33 PM |
Chrisg book would give you an idea how to make one, not so difficult.
iank
posted on 6/2/10 at 09:46 AM |
If using the design from Chrisg's book then I'd be going to 3GE to buy the bits (or one that's built up for £99 if it fits
properly).
http://www.3gecomponents.com/templates1/view_department.php?department=118&site=63
Anonymous
mistergrumpy
posted on 6/2/10 at 08:06 PM |
I bought a bias valve from Goaty on here that he had bought from Comp Brake and didn't need. It was big fat hairy rubbish. Badly built and just
didn't let the fluid flow at all. Badly designed. It's on the garage floor still with a hole drilled in it lying in disgust.
Not Goaty's fault in any way I might add.
Steve Hignett
posted on 6/2/10 at 11:18 PM |
Even though he'd never shout about it on an open forum himself, Matt's (Procomp) pedal sets are well manufactured adn not badly priced
either...
