Author: Subject: Wishbones
micklax
posted on 8/4/10 at 01:04 PM Reply With Quote
Wishbones
Hi
I am looking for some help on wishbones for a Locost Race car. I need to know whether they must fit the spec as outlined in the book, or whether the design is essentially 'free', as long as they fit the Cortina hubs and comply with the measurements as shown in the regulations.
I have acquired a set that fit the hubs and will fit the chassis (with some slight amendments to the pick up points).
Can anyone shed any light please?
Mick
blackie
posted on 8/4/10 at 08:52 PM Reply With Quote
Hi Mick, you need to read the Locost Racing Regs;
Linky
As they describe the front suspension "limits of acceptability". The limits in the regs were added after all the drivers at the time submitted the dimensions for their cars. So if you're making / buying wishbones per the book, you should be within the regs - it's just to prevent people taking the p&^s
DB
micklax
posted on 21/4/10 at 07:29 PM Reply With Quote
Wishbones - Pictures
Hi
Can anyone shed any light on these wishbones (Please have a look at the pics at http://mickslocostbuild.blogspot.com). They match the measurements from the book, and will accept the Transit track rod end. My issue is with the size of the other end, which should have bushes fitted.
The tube at this point measures about 10mm (inside dia).
Can anyone help with any way in which they could be used, or any bushes which might fit?
TimC
posted on 6/6/10 at 07:46 AM Reply With Quote
That is mighty odd...
Can't really think of an acceptable solution that doesn't involve replacing the tubes.
