Jon Ison
| posted on 22/5/10 at 04:17 PM |
whats your cheapest fix ever ?
This one as transformed the car, jubilee clip restricting return to tank from swirl pot.
Car runs perfectly now............
jacko
| posted on 22/5/10 at 04:19 PM |
Cheep Skate
afj
| posted on 22/5/10 at 04:25 PM |
thats the cheapest fuel pressure regulater ive ever seen
eerrrrrrrrrrrrrrrr
speedyxjs
| posted on 22/5/10 at 05:12 PM |
lol good one!
scudderfish
| posted on 22/5/10 at 05:59 PM |
What was the problem without it?
55ant
| posted on 22/5/10 at 06:19 PM |
thats excessive, its not even plastic, or maybe even a strong rubber band!, im sure plastic would be lighter too, think of the performance
away from cars, now cycling and building TT bikes
speedyxjs
| posted on 22/5/10 at 07:01 PM |
0.000000001 seconds on the TG track?
Jon Ison
| posted on 22/5/10 at 07:39 PM |
lift pump was running full whack all the time as it was just free flowing back to tank from swirl pot, this in turn was causing it to overheat (bike
pump on points) and then cut out/act up. Its 10mm all round so very free flowing, now Ive put some resistance in the return line its much better
doesn't over heat or trip.
paulf
| posted on 22/5/10 at 09:18 PM |
I had a similar problem , my red top pump was hammering away all the while, I put a .6mm MIG nozzle in the return from the swirl pot even now it still
ticks away like mad.
Paul
Jon Ison
| posted on 22/5/10 at 10:06 PM |
Paul
Why didn't I think of that, got some spare 0.8 tips, going in tomorrow.
bimbleuk
| posted on 23/5/10 at 08:07 AM |
On my way back from a blat my foot flicked the clutch pedal which made the nipple at the other end pop out the arm. So back in the garage I spotted a
spring which my soldering iron usually sat in and put that between the clutch arm and the bell housing. Stopped the arm rattling and retained the
clutch cable.
dlatch
| posted on 23/5/10 at 12:14 PM |
pumped up a flat tyre cost was £0
Ninehigh
| posted on 23/5/10 at 12:36 PM |
Brake light was staying on in me Astra, Vauxhall wanted nearly £200 to replace the switch... I sprayed some WD40 on it and it stopped sticking.
