stevem2727
posted on 28/5/10 at 05:09 PM |
running in my pinto
Hi just about finished rebuilding my 2.2 pinto.How would you guys recommend running it in and what oil should i use,cheers
philw
posted on 28/5/10 at 06:06 PM |
Theres a bit about it here if you read my linky thats how i did mine
Must try harder
Stott
posted on 28/5/10 at 06:47 PM |
As above really, rag it once you've bedded the cam in.
I used a cordless drill with a nut spinner on it with the dizzy out and spun up the oil pump untill the spray bar squirted over the cam so I knew all
the galleries were full then replaced the dizzy, timed it and fired it up.
This is a good idea with a new build, rather than turning it over with the plugs out to build pressure
Stott
davestarck
posted on 28/5/10 at 07:55 PM |
When I built my my last Pinto I pre packed the oil pump with vaseline (petroleum grease). Works a treat
