phelpsa
posted on 29/6/10 at 06:44 PM |
TIG welding in the south
I'm going to chop and baffle a sump for the GSXR engine, which will also involve shortening the oil pickup. I have the sump, i have the
aluminium plate (3mm) and by the end of the weekend I should have it all ready to be glued together. The only problem I have is that I can't TIG
weld
A friend has offered to do it in his half hour lunch break, but he's quite a distance away and i fear it may be more than half an hours work.
Would anyone else in the south be willing to help out a fellow LocostBuilder?
phelpsa
posted on 29/6/10 at 06:53 PM |
I probably ought to add that i'd quite like to get it done for the airfield day on the 9th July
pewe
posted on 29/6/10 at 07:47 PM |
Roger Clarke 12 Shaftesbury Rd just off Oxford Rd in West Reading usually turns stuff around in a couple of days and his prices are good.
Tel: 01189507735 just in case he's busy/on hols.
BTW is that N Weald? Craig (akaKeith) and I are going.
Cheers, Pewe ![](/images//smilies/cool.gif)
phelpsa
posted on 29/6/10 at 08:01 PM |
Thanks! Will bear that in mind
And yes, North Weald. Its a big rush to sort all the finishing touches on the car!
