smart51
posted on 13/7/10 at 11:32 AM |
Nyloc or plain nut and spring washer for MSVA
Do I need nylocs to keep the MSVA man happy or can I use plain nuts and sprung (spiral) washers? Nuts and washers can be reused if they have to be
taken off for some reason.
blakep82
posted on 13/7/10 at 11:34 AM |
i think both should be fine, but i'd go nyloc myself
________________________
mad4x4
posted on 13/7/10 at 11:43 AM |
Depends - Nylock or Nut and Spring washer should be ok. However different application require different technology's
A nyloc nut is technically a 1 use Item so it should be replaced every time. However a Nut and Spring or antishake washer can be used many times.
So if you need to take something a part a lot a spring washer & nut is better, but not always best or most practical. Also I wouldn;t use nylocs
on the exhaust or anything that gets very hot.
Scot's do it better in Kilts.
smart51
posted on 13/7/10 at 11:48 AM |
My first car had nylocs everywhere and it had to be taken apart to be fixed many times. I hated them because they need to be turned every millimetre
of the way and always seemed to be located somewhere inaccessible. With a plain nut, you loosen them off with the spanner then spin them with your
finger tips.
Long hours spent with arms outstretched deep into the engine bay turning a ratchet spanner one click at a time didn't help my fondness for the
nylon insert. And you have to keep replacing them.
blakep82
posted on 13/7/10 at 11:52 AM |
well, what i'm doing is using plain nuts while i'm building, but when it comes to the final assembly (eventually ) i'll put
everything together with nylocs. by that time, i shouldn't have to take it all apart again
mgmiller
posted on 13/7/10 at 12:05 PM |
loctite is also an acceptable
posted on 13/7/10 at 01:48 PM |
but you know you will have to ... and spring washers are cheaper and re-usable.
Bluemoon
posted on 13/7/10 at 02:13 PM |
but in my experience spring washers are not as effective.. Nyloc's, loctite (the correct grade for the job as well) or wire locking, or split
pins i.e. somthing positive would be my ideal for anything mission critical.
You can re-use nylocs twice the problem is how can you know how many times they have been used, thus safer to replace..
iank
posted on 13/7/10 at 02:31 PM |
Spring washers have got a pretty poor press here over the years.
The Nord-lock style ones are apparently much more effective.
http://www.nord-lock.com/
RS Components sell them, but they are quite expensive compared to nylocks - there are probably cheaper sources.
RS Link
Anonymous
AndyGT
posted on 13/7/10 at 05:56 PM |
nylocs have only have "about half" the tensile strength of a normal nut too as "half" of the threads are nylon not metal
Just my 2 pen'eth
nothing is impossible
everything is possible
posted on 13/7/10 at 06:01 PM |
I don't think the MSVA manual is that specific... as long as they're secure, then that's about all the guidance given.
It's Evolution Baby!
SteveWalker
posted on 13/7/10 at 06:21 PM |
We had a company come in last week with a different idea. Take a look at http://www.nord-lock.com (they're nothing to do with me!)
They are two serrated washers bonded together with a slightly compressible material.
mad4x4
posted on 13/7/10 at 08:19 PM |
Just my 2 pen'eth
You will find that a good nyloc nut is the thicker than the equivilent Normal nut - so we need to pass this theory to Mythbusters....... My 2
pen'eth
