Author: Subject: Wheel bearing noise
JeffJeffers
posted on 17/7/10 at 09:26 PM Reply With Quote
Wheel bearing noise
On my Audi A4 I have got a wheel bearing noise from the front. The noise goes when I turn left and gets worse when I turn right. Does this mean it's the left or the right bearing?
mookaloid
posted on 17/7/10 at 09:28 PM Reply With Quote
Left - er probably
l0rd
posted on 17/7/10 at 10:53 PM Reply With Quote
lift the car on axle stands
Grab the wheels at 12 and 6 o'clock and shake
repeat for 3 and 9 o'clock.
If there is excesive play, there is the guilty one.
I have had really bad experience with wheel bearings.
posted on 17/7/10 at 10:58 PM Reply With Quote
Ignore the advice about feeling for play, the best way is to support the car on axle stands and get someone to drive the car whilst listening at each wheel IF the fault doesn't show up by spinning the wheels
mediabloke
posted on 18/7/10 at 02:16 AM Reply With Quote
I'd say the right, most likely. The bearing will get noisier when unloaded.
Unless the hubs have been in bits, the case-hardening may have worn off. If they have been in bits, you'll find the offending side will stick as you spin the wheel.
A few years ago, I caught a local tyre-bay removing the rear wheels whilst still bolted to the drums on a previous car, by removing removing the stake nuts...
You should've seen the ridges in the bearing faces after they put the wheels back on the same way! Curiously, they replaced the bearings FOC when I threatened to sue...
posted on 18/7/10 at 09:23 AM Reply With Quote
I had a problem with my daughter's Corsa front wheel bearing rumbling. There was no play in it at all yet the noise it made when you spun the wheel was awful. When I took the hub off the outer was perfect but the inner looked like it had never turned it was gummed up solid.
Mark Allanson
posted on 18/7/10 at 09:29 AM Reply With Quote
Don't even bother trying to find which side - both have done exactly the same mileage, change them both.
StrikerChris
posted on 18/7/10 at 10:29 AM Reply With Quote
Do you work for an audi dealership?! That's all very well on old style bearings at a tenna each but now most cars you have to replace the whole hub,rarely getting change from £100 I'd try to find out which side it is first,might get another 12months out of the other one!
Mark Allanson
posted on 18/7/10 at 10:46 AM Reply With Quote
Yes - on the bodyshop side!
StrikerChris
posted on 18/7/10 at 10:52 AM Reply With Quote
Lol.
dlatch
posted on 18/7/10 at 11:54 AM Reply With Quote
although not a cheap solution it is still the correct one unless you are selling the car soon
l0rd
posted on 18/7/10 at 03:51 PM Reply With Quote
I had a wheel bearing that
Was not noisy, didn't have any play in it but everytime i used to take a left and right hand corner, i used to listen to a tick, tick. This noise was developed at 120K miles.
At the next service, while doing the brakes, we took the wheel bearings out which were in the car since new from the steallers and one of them was 3mm sorter.
posted on 18/7/10 at 04:24 PM Reply With Quote
Always the other way around IME, the loaded side gets noisier.
JeffJeffers
posted on 18/7/10 at 09:49 PM Reply With Quote
After an hour with the car jacked up and alot of wheel turning I went for the left.
After another couple of hours to replace the bearing the noise had gone.
I am selling the car soon so I'll just replace that for now.
Thanks all for the help.
