posted on 20/7/10 at 08:48 AM |
anyone else excited by these?
hinged pipe clamps, ideal for brake lines and appear to be undoabale.
mmmmmmmm gold
quote: In both the single and twin series, LBBU clamps are available in 3 sizes and cover all standard metric and imperial diameters between 4 mm
and 32 mm. The twin series is also available for different diameters upon request.
The UV, ozone and weathering-resistant material Santoprene with a hardness degree of 87 Shore-A, guarantees vibration and noise-reducing pipe and hose
installation.
A film hinge, which allows the top part of the plastic clamp body to open up, makes it easy to insert and replace the pipe or hose without the use
of force.
posted on 20/7/10 at 09:05 AM |
Excited by pipe clamps? You have to be joking?? Shirley....
mookaloid
posted on 20/7/10 at 09:20 AM |
as clamps go they are really very nice indeed - but excited? no not really
blakep82
posted on 20/7/10 at 09:36 AM |
gives me the horn lol
________________________
mrwibble
posted on 20/7/10 at 09:37 AM |
mmmmmmmm gold
installation.
of force.
hmm nipple clamps
omega0684
posted on 20/7/10 at 09:41 AM |
dude you need to get out more.......................
James
posted on 20/7/10 at 09:44 AM |
Looks like a great idea to me- nice secure way of clamping fuel pipe, brakes, even loom etc. etc.
Whether IVA man will be happy with just the bolt holding it though? Loctite needed at the very least I'd have thought. And of course, having it
bolted means fitting a rivnut which needs a much bigger hole in your chassis tube compared to a rivet.
James
- Muhammad Ali
A1
posted on 20/7/10 at 10:02 AM |
i need some time alone with these
MikeR
posted on 20/7/10 at 10:23 AM |
but if you've welded little strips onto your chassis with holes in for rivets - then welding a nut won't be much hassle .......
yes, i'm excited as well.... where do you get them from and how much are they (and when you answer that i'm sure i'll lose my
excitement).
[Edited on 20/7/10 by MikeR]
omega 24 v6
posted on 20/7/10 at 11:26 AM |
looks good ( so excited) but also look expensive for what it does ( excitement gone)
posted on 20/7/10 at 11:46 AM |
excitement).
http://www.stauff.co.uk/
You will need to register in order to download the price list though.
iank
posted on 20/7/10 at 12:04 PM |
Block of nylon a drill and a dremel and you could make as many as you want.
Anonymous
posted on 20/7/10 at 12:38 PM |
It is not quite that simple as the number you can make is limited by the size of the bit of nylon.
The point peeps seem to be missing it that you would never have to worry about the rivet heads rattling in your chassis with this system should you
need to replace a brake pipe.
Richard Quinn
posted on 20/7/10 at 12:55 PM |
You wouldn't with THESE either.
beagley
posted on 20/7/10 at 01:51 PM |
No, I'm not joking, and don't call me Shirley
I'm surprised nobody got the Airplane reference. One of the best movies of all time. Those pipe clamps look nice though, hope they make this
this side of the pond.
I'm not scared!!! I'm just marking my territory.
Richard Quinn
posted on 20/7/10 at 02:10 PM |
I think they did, they were just ignoring it.
I guess I picked a bad day to give up...
posted on 20/7/10 at 02:11 PM |
Glad someone got it
Hector.Brocklebank
posted on 20/7/10 at 02:55 PM |
yawn.....
you really need to get out more, and anyway those things are very old news for many....
but as said a lump of nylon on the mill and away you go.
Ninehigh
posted on 24/7/10 at 07:54 AM |
I take it the s**t is really going to hit the fan then?
Oh yeah and shave those sideburns!
[Edited on 24/7/10 by Ninehigh]
